Windows 8 sound issue
    windows 8.1 pro
    Hello,
    After deciding to give windows 8 another shot and installing windows 8.1 i still stumbled upon the same issue i had before. sound - YouTube In first part of the clip you can hear sound in windows 7 and in second how it sounds in windows 8. While windows 7 sounds perfect, windows 8 has this kind of "in fishtank" sound, not sure how to describe it and also really heavy and loud bass.
    Both windows are using the same realtek hd audio drivers. I guess there is something that needs to be either disabled or changed in windows 8, but im not sure where to look for it anymore.
    I have been messing around with realtek control panel but no luck so far. Since everything driver related were the same on both windows it's something inside windows 8 that does this.
    Windows 8.1 pro / Realtek R273
    Also using usb sound card for headset and realtek for my mic, i can use realtek for both but the issue is still there.
    Thanks!
    Did you try settings in "Sound effects" in the "Realtek HD audio Manager" ? Setting environment to None or just click on Reset ?
    windows 8.1 pro
    Im using USB sound card so i don't have such settings. So far ive got to point where sound ok (still worse then win7 i think), but when sound is recorded and played back there is still the same issue, so now id like to fix sound recording. With default windows drivers for my usb sound card it was fine, recording sounded just like i hear it, but when i install my usb sound card drivers (Creative sound blaster tactic 3d), i get the issue. Drivers are newest and supported by windows 8/8.1 as well (as homepage says). Tried both: regular install and install in compatibility mode for windows 7.
    Edit. If i use realtek to record sound it sounds just as it should, when recording sound from my sound blaster usb card it again has that deep and bassful sound. As i see it: when using default sound ports (realtek) then sound is being recorded from them, when using usb sound card sound is being recorded from somewhere else or trought something else.
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
Sound issue in Sound & Audio
Hello! I have an HP laptop running Windows 8. Yesterday Windows updates were pushed across that I'm quite sure did not upgrade me to 8.1. Since then, after leaving the Chrome browser, I seem to have lost sound...and iTunes opens but will not play anything. To regain sound, I have to run...
Hello! Having a bit of a problem and trying to see if there is an easy solution. I have a Surface Pro and I want to watch some video on it. I wasn't able to find a specific video app that would play MKVs, but I did find Files&Folders which has a built in player that actually does! Been...
Asus M4A88T-M sound issue . in Sound & Audio
hi, i've just installed Win 8 . when it finished , i had sound , but only from 1 speaker ( i have 5.1 ) i was trying to install M4A88T-M audio drivers , but it says that no HD AUDIO found , and then i tried to install AC-97 drivers , but there's no drivers for win 8 . is my motherboard that...
wierd windows 8 sound issue in Sound & Audio
Hallo there. I upgraded to windows 8 some weeks ago, as i got it trough dreamspark. I got this huge problem, on both my stationary, and my laptop sound keeps dissapearing for 4-5 secs every 2-4 mins. And it's really annoying. I got 2 soundcards on my stationary, and ive tryed using both...
Sound issue Windows 8 in Sound & Audio
Hello, I have sound issues on Windows 8 new desktop, in apps and in IE10 it dont play sound. When i open the "old" desktop and open in there Internet, its working. I have updated the Realtek sound card, but this not resolve the issue, does somebody know how to solve this issue?
