Using Desktop Beats Audio AND External Speakers -Possible?
    win8
    HP ENVY 20-d094 TouchSmart Desktop
    How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ...
    AND NOT have it over-ride the BEATS audio.?
    Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF)
    Is there a way to have
    BOTH speaker 'sets' be heard ??
    the Touchscreens Beats Audio & my external Boston Acoustics speakers ?
    thxs
    5-19
    Connect the speakers, assuming the BA speakers have an analog connection, to the headphone jack instead of the line out. Beats audio should be available on the headphone jack. This doesn't address why Beats audio is not available on the line out jack, unless HP has it set up for the internal speakers only, and you would need to contact HP about that.
    As far as both the internal speakers and the external (or headphone), that depends on what options you have for the IDT configuration. Some internal sound systems (such as my RealTek) have options to either have the speakers muted when the headphone is connected or have both the speakers and headphone.
    win8
    Thanks for the reply but here's what's happening
    Beats audio is an Intergral part of this EnVy touch screen computer. It IS the default speaker and audio system. There is no beats audio plug to connect separate beats audio speakers or unit to my computer it is the sound system with a beats audio interface program-
    I'm simply trying to add another set of speakers to the computers sound system -Somehow-- and have all four speakers work ✔️
    Most all in one PC's, such as yours are basically a laptop PC with a "desktop" display (Monitor). The Beats audio is just a software enhancement (addition) to the basic audio chip. If HP designed the Beats to ONLY be used with internal speakers then you are sunk and you can't get the Beats audio enhancement on external speakers.
    I asked you to try the external speakers connected to the headphone jack to see if you have it there. Did you try that?
    For all the speakers to work, which is not normally the way PC audio systems work, your IDT audio configuration panel (if you have one) would have to have an option to allow all speakers to work when something is plugged into the headphone jack.
    win8
    YES- I did try the headphone jack. It muted the Beats (PC audio sound) as I expected.
    I will try to find this IDT configuration area and adjust some settings if I can..
    Thxs
Hey all, I've been using a Windows 8.1 HP Envy laptop for quite some time with no problems. It used to have very strong headphone output, and I could hear it just fine even at 2-3% volume. However, a few days ago I made the mistake of going into the preinstalled Beats Audio manager and...
Windows 8.1 Genuius SW-G2.1 1250 external speakers ASUS K56CB laptop When tested on other devices, the sound system blows the roof off. On my laptop, it doesn't (max level on computer controls, media player and speakers knob is lower). I'm pretty sure it's not the soundboard, but I've...
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
I was wondering what the best Beats Audio for classical Music is. My current settings are Beats:80 Treble:45 Center: 80 Space:80 Focus:80
MY LAPTOP HP 6121TX I 7 SECOND GENERATION,BUT AFTER INSTALLATION WINDOWS 8 FUNCTIONS WELL,BUT BEATS AUDIO A SPECIAL AUDIO EFFECT OF THIS VERSION OF HP IS TOTALLY LOST...PLEASE HELP:cry: :D:D:D PRESS FUNCTION KEY+B..beats icon will appear in system tray... Right click the icon options comes up...
