Split two different audio outputs to playback devices?
    Windows 8.2
    Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers.
    I am wondering if there is audio management software.
    Similar to how if I am on Skype I can communicate through headset and hear them on the headset while the audio on iTunes by default is outputted through the speakers.
    Thanks for any input fellow window enthusiasts!
    hehe I want to play Nether and hear everything through the headset and keep music playing on the speakers so my girlfriend does not hear me play games -_-
    7601.18247.x86fre.win7sp1
    If the headset is also connected to the same audio interface (for example, your onboard audio codec) - then no. It depends on the hardware itself and the drivers, but again, usually just no.
    Now if you had two separate audio interfaces, for fictional example off the top of my head for proof of concept purposes: A Realtek HD Audio onboard, and a USB audio solution, then yes, you can route the iTunes (if software allows - I don't use but it should) to the USB and the game will default to Windows default Realtek.
    I use my onboard alongside my MOTU Traveler firewire interface simultaneously at times to achieve various purposes, but as of late I have onboard disabled in the bios.
    lmao good a reason as any I suppose.
    Windows 8.2
    Quote Originally Posted by MasterChief View Post
    Hmm the speakers are connected through the onboard audio on the motherboard while the logitech headset is connected through USB. Hmmm
    Oh ok, then yes, probably so. Does Logitech show as its own audio device in the Device Manager's "Sound, video and game controllers" section? If it does, then you'd be in business.
    Windows 8.2
    To control my playback devices I go to the default sound manager, referred to the attached picture : )
    I wish I can set both items as default devices but have no idea how to..
    What would also be ideal is in the Volume Mixer under the Logitech Speakers I can mute all but the game then then under Desktop Speakers (High Definition Audio Device) I can mute the game.
    Any input would be greatly appreciated = D
    Can't set both as default.
    You have to set the outputs in the actual software themselves, for where you want them to go.
    Some games have that ability, some do not. iTunes definitely should.
Hey guys. I discovered that besides VLC player on my laptop all the other video player are not able to work properly (meaning,, Windows Media Player 12, Cyberlink PowerDVD12 and WMPC are able to play only the audio, but not the video, it's just black screen),, BUT with VLC is no problem playing...
i cannot see my graphic equaliser for audio playback - not in the music player but in general. example - i am watching something on youtube and want to adjust the audio but within my sound options i dont see graphic equaliser at all . i done have a dedicated sound card yet but until i do i need...
I was watching a TV show in my headphones, plugged it out for about an hour, plugged it back in during which time my Dell Inspiron 15 would have gone to sleep about 4 times.. I plug it back in after an hour and the music plays through the speakers and I looked up all solutions. None of them work....
Split audio in Sound & Audio
Hi, just gone back to Windows after using Mac OS for several years and was wondering if the following was possible. To have my Voice Chat program (Mumble) and game sounds to come through my headset, mumble is currently working fine. And then my game sounds to also come through my headset. But...
So i want to have a different output for 2 Programs. Problem: Both have not an option to change the audio device. One is: WiMP. Second is: World of Tanks. I want my Game to go to my Speakers (example) and my Music to my Headset (example). Though, none can be configured. So i looked up a bit, and...
I need to split my audio into two separate audio devices (my front and rear audio jacks). A physical splitter is not an option. The situation is this; I have an infrasound system that vibrates my desk at sub-audible frequencies, and I hear audible sound through my headphones. I would just use a...
