AOL 'mail-notification' sound suddenly gone !
    Windows 8 (plain '8')
    have AOL free mail program - suddenly,( tho properly 'set/saved' )the 'new mail' notification sound has stopped. Even in ''preview' it won't play... i did nothing to stop that. I do have Win. mail notification 'set' for a sound -would that setting over-ride AOL's ?
    thanks in advance - Edythe
    Quote Originally Posted by edythe View Post
    ok -it's edythe: solved my own problem ... i had disable Adobe Flash Player ''plug-in' to stop annoying ads at websites - apparently that also controlled the AOL 'mail notification sound'' .. problem solved.
When I play game or listen to music, It suddenly turns off sound. If I hit the mute button and hit again, It will OK. Or, I change the volume, It works.But after time, It turns off.Is this hardware or software problem. I remember that everything is OK before I bring my laptop to Clean Center. What...
Email notification sound in Sound & Audio
I`ve read all of the tutorials on setting an email sound for Outlook 2007 but to no avail. All of the notification settings are on and in control panel/sounds/ i set to both Desktop mail notification and new mail notification but still not getting a sound for new emails arriving. Could you help...
It's definitely not a hardware problem as one minute it's all working, then it suddenly stops. I've tried everything. My sound card drivers are all up to date, it also happens at the same time as youtube videos stop playing on google chrome (despite them loading), windows media player is unable to...
How to Change New Mail Notification Sound in Windows 8 and 8.1 This tutorial will show you how to change what sound is played by default when you get a new email in Windows 8, Windows RT, Windows 8.1, and Windows RT 8.1. Here's How:
I installed Windows 8.1 earlier and had this (apparently common) watermark error on the desktop about SecureBoot having a problem. I went into my BIOS, made sure it was enabled, and then set up some kind of "key" that the directions said to do. I clicked save and exit, and after that instead...
Is it possible to change the alert sound?
Solved new mail notification in Sound & Audio
:( Have entered a sound file in the "new mail notification" area of the "Sound" dialog box. When the "test" button is clicked the sound file plays, but when I receive mail I hear nothing not even windows default sound. shewood1
