AMD HDMI Output 'not plugged in', no sound
  1. #11
    All I did was follow your links and downloaded and installed both of them directly through their exe files, neither of them worked.
    But I'll try this now.
  2. #12
    Yeah I'm on their page but it seems a bit cluttered, what am I looking for on here?
    -UPDATED- Never mind, I found it.
  3. #13
    By the way, I feel stupid for saying this,
    But I don't want to use the HDMI sound output thingy. I want to be able to use my inbuilt speakers just like on the mac side of this computer. Sorry if I didn't clarify that earlier. Anyway, the download on this file has 5 minutes left, I'll update you and tell you how it goes.
  4. #14
    7601.18247.x86fre.win7sp1
    First thing is first.
    When you are done with that, you should also go into the bios settings and make sure integrated or onboard audio codec is set to yes, enabled or on then save.
  5. #15
    I installed the Catalyst files to no avail. Seemed close, but no cigar.
    I'm absolutely stumped at this point and I have no idea what there is left to do to fix this.
    With the mac side of my computer corrupted, I am now left with a computer that has no sound at all.
  6. #16
    windows 7
    I'm having the same problem. I tried installing the intel download mirror and it says my computer does not meet the requirements.
Page 2 of 2 FirstFirst 12
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
HI, I'm new here. I run the sfc /scannow like 5 times because when I did it, it broke or damage my HDMI output. The only problem my sfcdetails.txt file shows is that it cannot repair Amd64\CNBJ2530.DPB of the prncacla.inf file due to a hash mismatch. But you already wrote that it doesn't had to...
HDMI output not working in Graphic Cards
Hey guys, I have an ASUS s550C running windows 8 and my HDMI to my 32" RCA flatscreen doesn't work anymore. The cable works fine with the xbox, correct tv modes, but now as soon as I plug in the HDMI to the Ultrabook the Ultrabooks screen goes black and the tv screen says unsupported. What gives?...
Okay so, my computer recently crashed and had to reformat it.. lost everything :( Everything was working just fine, until I had to reformat. Now, I have no sound at all coming from my headphones and it says that the AMD HDMI Output is not plugged in. I don't really know how to fix this.. ...
HDMI Sound output issues in Sound & Audio
Hi there, new to this forum but i've been searching around today trying to find an answer to this problem i'm having. I've bought an HDMI cable to connect my laptop to TV, i've gone into the control panel and checked that "show disabled devices" and "show disconnected devices" are both...
