No In Game Sound and opening dxdiag error
  1. #11
    Quote Originally Posted by archer View Post
    You have to uninstall the drivers first from Control panel and then run Driver sweeper. If it is not able to find any files, that means there are no files left for it to clean. Install the latest driver for your sound card and then install DirectX 9. The link is provided in my post above.
    what is this?? There are 3 sound driver in my computer. I don't know what to delete. Please guide me
  2. #12
    Here another prob about directx
  3. #13
    asd
  4. #14
    still no sounds
  5. #15
    India
    Windows 7 x64/ Windows 8.1 x64
    Woooh! This is strange! Do you have 3 sound cards on your mother board? I will suggest you to completely remove all the drivers. But, before you do that make sure you have the motherboard DVD handy (which came with the hardware). Once all the drivers are removed. Insert the DVD and from that select the sound drivers (ONLY). Reboot and then check.
  6. #16
    I tried deleteing the asus and the creative. but there are no entries it means no driver. But I tried deleteing through driver sweeper the realtek it deleted. what does that mean? I already reinstalled the realtek now. Still youtube has sounds in browser some othe games but my league of legends and need for speed shift 2 has none
  7. #17
    India
    Driver sweeper detects the drivers from Realtek and it removed some leftovers it found. Now you have re installed the drivers again. Did you try to re install the DirectX from the link provided above.
Page 2 of 2 FirstFirst 12
I had this couple of bsod in the last month and they came up from nowhere, i dont recall installing anything
Hello everybody it's been a longtime. I recently found out a game of mine may have some stuttering problems due to it's audio being played without a discrete and/or external sound card of any type. So on your advice, i'd like to know if an external USB sound card can help with some of my...
So i was playing halo 2 pc when i got a voice message. Since i always use my trusty mic headset i click play on the message and it said no playback device detected and i tried fixing it with ingame options but it didn't work! and my browser doesn't either. i tried to record my voice but mic wasnt...
Hi Everyone! I play lots of games on my laptop, but a game I used to play daily started acting goofy about 2 weeks ago & even the tech support people at Wild Tangent are baffled. I hope someone here knows how to fix this, as I'm going nuts without my favorite game to play! I'll try to provide as...
I'm in the market to buy a headset for chat in online gaming, at the moment game sound is through my gtx cards hdmi to my tv speakers and I want the headset for purely just voice (like Xbox). In layman's terms how would I set it up this way? A friend said he thought the game sounds as well as...
Hi, I don't know if there's another thread regarding this problem but every time I run dxdiag, It asks me to bypass Direct3D. If I don't, dxdiag crashes and if I do, there's a lot of missing information in it. Here's a screenhot.22607 I also have this problem with the colors in windows 8. I...
Dxdiag stopped unexpectedly in Performance & Maintenance
I just noticed this and I'm not sure why dxdiag keeps crashing at the end. Clean install drivers by nvidia(stable and beta) doesn't seem to fix it. updated windows and even reapplied the update that specifically copies a fres ntdll.dll. I'm stumped at this point. Any ideas? ...
