no sound soundblaster audigy fx
    windows 8.1
    I Installed the soundcard but I get no sound the mic works but the sound seems to be conflicting with the graphics cards high definition audio
    If you installed a separate sound card, you must disable the on board (on the motherboard) audio in the BIOS. Both sound devices enabled can cause conflicts or the on-board to override the new SoundBlaster.
    The Video card's HDMI audio is normally only active if an HDMI cable is connected, otherwise your SoundBlaster should be set as default audio playback device. With the SoundBlaster you should set your default recording device to "What You Hear" (what SoundBlaster calls the System Mixer).
    windows 8.1
    fornt panel and mic
    its not detecting the front panel and mic ports either their not showing up in sound as disabled
    Please fill in the "My System Specs". Also, is the integrated audio disabled in the BIOS? And, did you install the SoundBlaster drives and support software?
    windows 8.1
    system specs front mic and speaker still not detected
    I filled in system specs
    the front mic and headphones are still not detected by the Audigy software
    Did you move the front panel headphone/mic connector from the motherboard to the new SoundBlaster card?
    windows 8.1
    mic to front panel board
    yes I did I have it working stable now but I had to disable my graphics card audio
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Beta Driver Creative Sound Blaster Audigy 4 Driver (Beta) Filesize : 40.42 MB Download Release date : 4 Oct 12 File Name : SBAX_PCDRV_WIN8_BETA_LB_2_18_0017.exe This download is a beta driver providing Microsoft® Windows 8 support for Creative Sound Blaster® Audigy® 4. For more...
I've tried everything to get my soundblaster working in windows 8 by upgrading drivers etc but haven't found a solution...Has anybody else had problems with this?
It seems that the soundblaster cards are currently not working with Windows 8. To be expected since this is a pre beta. But I installed the drivers for my Extreme Gamer and it was crashing every few minutes. I then reinstalled Windows without installing the drivers and it was STILL crashing every...
