no sound soundblaster audigy fx
tice1231
I Installed the soundcard but I get no sound the mic works but the sound seems to be conflicting with the graphics cards high definition audio
    windows 8.1
    Gateway DX4375g
    AMD A6-5200 2ghz
    6gb stock ram
    zotac synergy edition 4gb
    42 in tv
If you installed a separate sound card, you must disable the on board (on the motherboard) audio in the BIOS. Both sound devices enabled can cause conflicts or the on-board to override the new SoundBlaster.
The Video card's HDMI audio is normally only active if an HDMI cable is connected, otherwise your SoundBlaster should be set as default audio playback device. With the SoundBlaster you should set your default recording device to "What You Hear" (what SoundBlaster calls the System Mixer).
fornt panel and mic
its not detecting the front panel and mic ports either their not showing up in sound as disabled
    windows 8.1
    Gateway DX4375g
    AMD A6-5200 2ghz
    6gb stock ram
    42 in tv
Please fill in the "My System Specs". Also, is the integrated audio disabled in the BIOS? And, did you install the SoundBlaster drives and support software?
system specs front mic and speaker still not detected
I filled in system specs
the front mic and headphones are still not detected by the Audigy software
    windows 8.1
    Gateway DX4375g
    AMD A6-5200 2ghz
    6gb stock ram
    42 in tv
Did you move the front panel headphone/mic connector from the motherboard to the new SoundBlaster card?
mic to front panel board
yes I did I have it working stable now but I had to disable my graphics card audio
    windows 8.1
    Gateway DX4375g
    AMD A6-5200 2ghz
    6gb stock ram
    42 in tv
