No audio to HDMI monitor speakers
    Windows 8 Pro
    My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't remember exactly what is was called, but it was a somewhat vague name like "audio device"), and I've tried various settings, yet I can't get sound from the speakers.
    So my question is, does an HDMI connection on a monitor support audio, or does he need to get a audio cable and use the green audio jack that is on the monitor, which I thought was just needed with the VGA connector.
    Thanks
    It depends on what is available on the specific PC. Normally, both Video and Audio are on the HDMI port, and when a cable is connected to the HDMI port Windows automatically changes the default audio playback device from the "Speakers" (The PC's sound card) to the HDMI as the default audio playback device.
    Since this is not happening, either the incorrect video driver (which includes HDMI audio) is not installed or the PC does not have the capability.
    About all I can offer without the specific Sony PC Model Number so we can research what it has.
    Quote Originally Posted by Vincenzo View Post
    Thanks
    My wife's older HP laptop did the same thing....what I ended up doing was right clicking the sound icon, selecting playback devices and manually selecting the HDMI output. Now my 2 year old Samsung picks it the connection with no problem at all.
    Yup, amazing at it sounds, sometimes Windows just doesn't work as intended.
    Right click on the speaker down by the clock, choose "Playback Devices" and right click on the HDMI output (might be called something else but you should be able to figure it out) and set as default device.
    Windows 8 Pro
    Thanks for the replies. I did try the above when I was working on it, did not help.
    I emailed my friend to get his computer's model #, and he says it is working OK now. I won't see him for a few days to find out what changed.
    Thanks
Problem: AMD HDMI output would not play sound via HDMI cable to monitor speakers. Testing the AMD HDMI sound output gave the following error message: Device in use by another application… This FIX worked for this hardware configuration. · MSI motherboard · Realtek Audio...
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel 9.17.10.3040 Playback Devices
Very helpful forum so thanks in advance for addressing this - I have an Asus laptop running Intel Display Audio and I have it connected to an external monitor via HDMI. I also have external logitech speakers, which for whatever reason, sound a lot better when plugged in to the monitor than the...
Hi, before I state my problem I just want to clarify that this didn't occur before updating to windows 8.1. Before the update my sound would switch between the tv and the laptop speakers automatically when as I unplug and plug in my hdmi cable. Now, I put my laptop to sleep when not in use or when...
monitor and HDMI in Graphic Cards
Hi, I connected my Fujitsu laptop to the "dining room" Tv (Its a cheap technika from Tesco 22") via HDMI cable, with immediate results. I then tried to connect the laptop to my new monitor Asus VE228HR 21.5". This is my main monitor connected to my desktop PC via VGA with a dual connection to...
firstly this is my first post so sorry if i sound noob. ok so i installed windows 8 consumer preview build 8250 x64 last night. everything seems to be working correctly other than my sound. i am using VT1708s by via embedded in a asus m5a78l-m/USB3 motherboard now the problem is the sound is...
