Duplicate sound device entries in volume mixer
    Hey guys basically i have an ASus ux301la (zenbook infinity) and i noticed that after installing Displaylinks software (port replicator software) my default sound device was called (USB AUDIO) and that my Realtek sound device kind of went missing (no sound devices on the playback tab in the sound settings). I had no backups at teh time as its a new laptop and i really dont want to re-install 8.1 from scratch as it took me over a day to configure this thing to my personal config.
    so i uninstalled the diplaylink software and uninstalled/reinstalled the sound drivers from the asus site and each time i did so it would create a new sound entry, hence all teh duplicates. Now i still have a problem because although sound works, i have to manually select the correct playback device in VLC player and i cannot see any sound devices in the playback tab on SOUND settings. Any advice welcome
    Click image for larger versionClick image for larger versionClick image for larger version
    Go to the Device Manager. There are probably multiple entries there too. If there are, uninstall them all (but do not uninstall the drivers). To Uninstall, RIGHT click on an entry to highlight it and then LEFT click "uninstall". Restart the PC and when Windows starts it will detect the sound and reinstall it. That should get you back to just one,
    i wish that were teh answer. tried that a few times and thats why i have so many duplicate entries lol.
    i noticed some strange behaviour though. when i uninstall the drivers via device manager the speaker device would appear in the playback tab on the sound properties. then after i closed the sound properties and re-opened them, the list would be empty again.
    Can you post a screen shot of the Device Manager and the Sound section?
    Screenshot - Capture Screenshots Directly in Windows 8
    When you uninstalled in the Device Manager did you restart the PC? If you uninstall and then restart the PC, Windows should detect and install it as a new device. All the older entries for the device should have been removed.
    If nothing is shown in the Control Panel/Sound Panel, RIGHT click in a blank area in that panel and then click to show Disabled and Disconnected devices. See what now shows up.
    Thanks for your reply.
    I did restart the pc each time and the entries were not removed.
    as for hidden/disabled devices. None appear.
    Weird behaviour is after installing/uninstalling the drivers, a device appears in the "sound" properties but then dissapears after reboot. Sound still works even though there is no device.
I am trying to install pinnacle studio 16 ultimate in windows 8. They say it is compatible however I am not getting any sound in the programme. The helpline says I need to turn on sound for this programme in something called volume mixer or audio mixer. Where and how do I find this in Windows 8. I...
Hello All, I just looked at Device Manager on my Windows 8.1 Pro desktop PC and when showed hidden devices I noticed that I have several duplicate entries for the same hardware. Here is a screenshot: 53044 The only thing I can think of that might have caused this was that I just did a...
Volume Mixer Problem in Sound & Audio
Hello guys, So i got a problem on the Volumer Mixer. All started yesterday after i decide to install my new speaker... now is giving a headache to fix to the way that was before. Basically before i could control all the computer volume but now when i go to volume mixer there is a lot of stuff...
Volume Mixer Frustration in Sound & Audio
I have a Qosmio X870-BT3G23 laptop with Windows 8.1 installed. When playing a game, I noticed sound volume got quiet. When I alt-tabbed out of game, I noticed volume mixer sliders were not all set the same. I moved them all up to match main Speaker level, but it is frustrating to keep setting them...
volume mixer settings in Sound & Audio
ok... someone look at the screenshot of the volume mixer and tell me those squares belong....
Volume mixer in Sound & Audio
Hi all, after so long I've been using Windows 8, I noticed this feature(?) in this OS. See attachment. My question is: Why is every application's volume is half of the device volume? I tried moving the bars of the app's volume to match the device volume, but it will go back to the...
