audiobreak
Hi guys,
I'm having a little problem with my onboard audio, having just installed Windows 8.1 (clean install). I have an Asus P8Z77-V LE PLUS motherboard, which includes a "Realtek® ALC889 8-Channel High Definition Audio CODEC" onboard.
I have installed the latest realtek drivers; R2.73 from the official website.
Now, here's my problem: when I was using Windows 7 on this same machine, I could plug headphones in the front panel connector, as well as speakers in the green back panel connector. This would give me two audio outputs in the device manager/sound list, which was pretty practical and enabled me to output different applications through the speakers or the headphones.
Now, however, there's only one output, irrelevant of whether or not I have two outputs plugged in at the same time. They appear in the device manager as a single device called "speakers" (see picture). Instead of both having separate outputs, they both output exactly the same audio.
Any solution to this?
- Windows 8.1
