How to change startup sound
    Windows 8.1 64 bit
    Hey guys I was just wondering if you know how to change the windows 8.1 startup sound without messing up the metro. Thanks
    Windows 8.1 (x64)
    Windows 8.1 64 bit
    Thank you, but will this mess up the metro because I have heard of some methods messing it up
    I haven't test changing the startup sound in Windows 8, but if it does cause an issue, then running a SFC /SCANNOW command to repair the modified system file will fix it.
    SFC /SCANNOW Command - Run in Windows 8
    Windows 8.1 64 bit
    Thank you and have a merry christmas!!
Ok first thing is that I've already been looking for a solution through google and I did come across this: http://i.imgur.com/xmSnqUM.png I changed it to what the picture shows and my volume is still very quiet. I've also checked if my drivers were up to date and they were. The strange thing...
Greetins all, Is there a way for me to decide where what sound is played? I got it setup now that all communication is played though headset but all other sounds are sent out though the HDMI cable to my sound system. I know some games and application allow me to select under options...
where can I find the startup sound that i'd like to replace ?
I am trying to figure out how to change my picture on my Windows 8 startup screen. I looked at a few tutorials on how to do it; so far nothing has worked out for me. Thanks everyone!!!
Is there a way to swap left and right channels ? I couldn't find a way in my titanium x-fi sound card settings and software . Thanks.
I'm so sick of hearing vista's startup twinkle. It flat out sucks. I wish the Longhorn startup sound made it, now that is glory! When you think of it, we've been hearing the same startup sound, shutdown sound, and others for at least five years now...
