Windows 8.1 - Sound Settings not "sticking" ?
    Windows 8.1 64 bit
    Hey gang,
    I wanted to go in and customize a little bit of my Windows sound events.
    Like for instance, the recycle bin sound , the windows log off sound, even a couple of sounds for Quicken.
    I found where we can restore some of the sounds for Windows 8.1 that had disappeared, or at least restore them to where they are selectable.
    So I went in and added the windows log off sound, the recycle bin sound, and changed a couple of the sounds for Quicken. Click apply to set them.
    However I have found upon signing off and back on or restarting the system, they do not save and revert back to what they were. Am I missing something here?
    Thanks for any tips,
    - Don
    Apply button works only for that session, you have to press OK or something like that to "stick" for the next boot.
    Windows 8.1 64 bit
    Thanks for the tip, for whatever reason though my changes are just not sticking. When I change a sound it then shows default ( modified ), upon restart it still shows that, but the customized sounds I made are no longer there.
    No biggy I can live with the default sounds, just wanted to add a couple for Windows and change a couple in my Quicken program - they all just revert back to default on a restart.
How to Boot to Advanced Windows "Startup Settings" in Windows 8 The new metro style Advanced Boot Options menu for Windows 8 includes various system repair, recovery, and troubleshooting options to help you fix at boot. The selected option will remain in affect until the next time you restart...
How to Open "PC settings" in Windows 8 and 8.1 In Windows 8.1 and Windows RT 8.1, there are a few different ways to find and change your settings: PC settings, Control Panel, the Settings charm, and Search. Most of the settings that you'll want to change can be found in PC settings. The PC...
I just recently changed my OS to Win 8.1 (from Win 7) and a java application I have (*.jar) is pointing to Python to open it. THis is obviously wrong. If I download the latest version of Java and install it, the icon changes and the app works great. The "jar" externsion is associated with java. ...
Yesterday I created two local users with admin rights, I changed their account pictures and changed the background color. Everything worked fine. Today when the other user should log in, she wasn't happy with her account picture. So I showed her how to change it. However, when she pressed her...
I have just installed Windows 8 Pro onto an existing Windows 7 Pro drive allowing dual boot. The problem is whenever Windows 8 is running I hear a sound every now and then. The sound is the "close program" default sound "ring07.wav. Why is this happening and how can I stop it? Thanks.
How to Download a "Search Settings" Shortcut in Windows 8 and 8.1 This tutorial provides a download of a "Search Settings" shortcut that opens directly to the Search charm flyout screen with Settings selected in Windows 8and Windows 8.1. You can also press the Windows :winkey: + W keys to...
