Bluetooth (or Wireless Speakers) Questions
    I am one of these old fashioned people who runs a tower base unit and a separate monitor - But I would like to play my music from this PC to others rooms......my thinking was that I would need a bluetooth dongle - and some bluetooth speakers ? .......or could I just get away with Wifi speakers ?
    I have a terrible taste in music - so don't want to spend loads......any suggestions...... [uk based poster}
    Bluetooth would be the way to go, however I don't know the distance capabilities of Bluetooth. I don't know anything about wi-fi external speakers. There are wireless devices available - you connect the wireless transmitter to the PC's analog sound output and the receiver to the powered speakers. These will work in separate rooms.
Can i do this from Windows 8? I've heard there might be a 2 second delay! Thanks
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
Asus All in One Asus ET 2410 IUTS 23.6 Desktop Can I connect the Grace Digital Matchstick Speaker Dock that I have for my Kindle Fire HD to my Asus desktop? I am not familiar with Bluetooth and whether I need connections or software to do this. I might need a different kind of Bluetooth...
Hi! Nice forum here. I'd just like to know how to use my laptop's speakers via Bluetooth to play music from my 4th generation ipod touch. I know it can be done on windows 7, but there aren't any guides for windows 8. I also know there is the option to stream over wifi, but this doesn't...
Hi there I'd like to make a suggestion here to people wanting external speakers for things like laptops etc. Go for BLUETOOTH wireless rather than USB ones since it saves using a USB port (especially on newer ultra books where the number of USB ports is limited anyway) and gets rid of messy...
Hello all. I have an HP Pavilion dm4 3050 laptop. I have spent a lot of time trying to fix my bluetooth problems since updating to 8, and now I need some help! I go into add a device in a the CP and the machine finds the bluetooth speakers and I add them. I then right click them-> sound...
Hi there. Tried to pair a Logitech Miniboombox on to a W8 virtual machine using vmware workstation. The built in Bluetooth adapter didn't work but a USB bluetooth adapter could be attached to the VM and the device paired instantly. Is bluetooth not supported natively by vmwware. The USB...
