Help About Audio output in Windows 8
    Pakistan
    windows 8.1 Enterprise
    i have installed windows 8 pro 32 bit .
    but the probelm is faced .
    the audio service is runing in both sides, when i am plugging the headset the sound is coming in both sides I mean that in headset and also in loudspeakers.
    i want to play sounds only on headset when i plug the headset ,
    please tell me that how to fix this problem please please
    Pakistan
    i have realtek Audio Device
    Windows 8 Pro
    There are 2 options , either the settings are wrong or the realtek audio service keeps crashing on you.
    if it's settings....see below (1) , if it's the service , you may need to re-install the drivers but a quick fix is to open the realtek control panel that will re-start the service.
    (1)
    Open the Control Panel the click on RealTek HD Audio Manager then in the window that opens select Speakers.
    In the right hand column under digital or analog, depending on your settings, you’ll see your mic and headphone inputs represented by small circles.
    If nothing is plugged in then they should both be greyed out and unavailable, plug in your headphones if they are not already plugged in.
    The headphone circles should now be accessable, by that I mean not greyed out.
    Right click and select “Connector Retasking” You’ll get a dialogue box pop up that says “The current connected device is”, Select “Headphones”.
    You will also see “Enable auto pop up dialog when device has been plugged in” check the box next to it and click OK.
    Your speakers should now cut out when your headphones are plugged in and you will get a dialogue box allowing you to change the setting should you wish.
    First, if you do not have the correct RealTek sound driver, that is the first item. If you only have the generic Windows installed "HD Audio Codec" you need to install the correct RealTek driver.
    The Realtek HD Audio Manager, in many systems, has an option for speaker/headsets. On the systems with the option, you can have the speakers mute when you plug in headset or do not mute the speakers when the headset is plugged in.
    In mine, the Blue color "Device Advanced Settings" in the upper right of the panel is where the headset/speaker option is found.
    Pakistan
    i was not installed realtek hd audio driver. I installed Windows 8 and the all drviers are automatically installed, after few days i plugged the headset the problem is faced
i have a dell inspiron 14z 5423 laptop which supports IDT high defination audio driver . . . when i try to insltal it from the site the box says that " the hardware detected is not supported by this IDT .software package . . the install will be aborted . . .but in the dell site it shows that my...
No audio input and output in Sound & Audio
Well, things went on until noon yesterday, but suddenly My PC takes no audio input or gives any output. I have tried reinstalling driver, checking mute button, checking Cables etc, none of the audio devices work on my PC which work in other devices. On opening realtek audio manager and playing...
Hello, I have a Toshiba Satellite L875-S7110 with Windows 8 that is a few months old now, and had been working fantastic until last night. Windows did an update, and now I have a red X over my sound icon that states "No Audio Output Device is installed." Things I have tried so far to try...
Hi, I have a compaq presario V6500 which came installed with Windows Vista. I recently upgraded my OS to Windows 8 (last month). Today, just like that, the sound was lost, while I was listening to a tutorial online. The sound icon on the desktop taskbar says "No Audio Output Device is...
I hae a dell m1710, installed win8 rtm on it. In win 7 i have 2 options of digital audio out: 1. Turtle Beach Audio Advantage Micro usb with optical S/PDIF out 2. Dell composite video adapter with digital coax out. Sigmatel high definition audio codec In win 8 i tried first the Audio...
