Solved Help About Audio output in Windows 8
maamiradina
Pakistan
i have installed windows 8 pro 32 bit .
but the probelm is faced .
the audio service is runing in both sides, when i am plugging the headset the sound is coming in both sides I mean that in headset and also in loudspeakers.
i want to play sounds only on headset when i plug the headset ,
please tell me that how to fix this problem please please
    windows 8.1 Enterprise
    HP ELITEBOOK 6930P
    Core 2 vpro
    Mobile intel 4 series express chipset family
    Avast
i have realtek Audio Device
    HP ELITEBOOK 6930P
    Core 2 vpro
    Avast
There are 2 options , either the settings are wrong or the realtek audio service keeps crashing on you.
if it's settings....see below (1) , if it's the service , you may need to re-install the drivers but a quick fix is to open the realtek control panel that will re-start the service.
(1)
Open the Control Panel the click on RealTek HD Audio Manager then in the window that opens select Speakers.
In the right hand column under digital or analog, depending on your settings, you’ll see your mic and headphone inputs represented by small circles.
If nothing is plugged in then they should both be greyed out and unavailable, plug in your headphones if they are not already plugged in.
The headphone circles should now be accessable, by that I mean not greyed out.
Right click and select “Connector Retasking” You’ll get a dialogue box pop up that says “The current connected device is”, Select “Headphones”.
You will also see “Enable auto pop up dialog when device has been plugged in” check the box next to it and click OK.
Your speakers should now cut out when your headphones are plugged in and you will get a dialogue box allowing you to change the setting should you wish.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
First, if you do not have the correct RealTek sound driver, that is the first item. If you only have the generic Windows installed "HD Audio Codec" you need to install the correct RealTek driver.
The Realtek HD Audio Manager, in many systems, has an option for speaker/headsets. On the systems with the option, you can have the speakers mute when you plug in headset or do not mute the speakers when the headset is plugged in.
In mine, the Blue color "Device Advanced Settings" in the upper right of the panel is where the headset/speaker option is found.
i was not installed realtek hd audio driver. I installed Windows 8 and the all drviers are automatically installed, after few days i plugged the headset the problem is faced
    HP ELITEBOOK 6930P
    Core 2 vpro
    Avast
