sound bars
    nottinghamshire
    windows 8 & windows 7 /samsung tablet 10 1 / acer chromebook/ Lenovo win 8,/10
    sound bars
    Hi could someone give me a bit of advice please i have a 60 inch smart tv samsung the sound is not as clear as i would like so i am thinking of a sound bar i have no idea where to start .ie the size .has it got to match the size of the tv has it got to be the same make as the tv ??? any advice appreciated
    Windows 7 Professional
    Quote Originally Posted by Bosslady View Post
    Not sure you'll get a real answer here. This is a Windows 8 forum, not one that usually deals with something unrelated like this.
    nottinghamshire
    sound bars
    ok , just thought with it being a smart tv with computer built in some one may have had knowledge of the sound bars
    also i posted on sound and audio !!!!!!!!!!!!!
    Google for "HDTV forum" and you'll find several very good forums that discuss not only hdtv but stereo and all things related.
    Sound bars are used to replace the front satellite speakers, you give up some sound quality but they can be better if you are limited in space. If you want really good sound at a affordable price there are several very good, low cost, 5.1 satellite systems on the market. For optimum results you should have a 5.1 A/V receiver, these can be found at affordable prices also. A self amped sound bar would not need any of this.
    The newer Samsung smart TV's are pretty cool, easy to surf the net with, but not really a computer.
    nottinghamshire
    sound bars
    Hi madcratebuilder can i say thankyou for your advice that has helped me a lot . i knew someone would come along with knowledge of my query , this is a brilliant forum i must say it has helped me many times , many thanks again much appreciated
sound bars
I have 2 USB sound bars connected to usb ports on my pc. Under sound settings I can only select one of the sound bars as my default speakers. Is there some way to select the second as well?
Charm bars suddenly disappear in General Support
Out of nowhere my charm bars will disappear and even the right-click on the windows symbol on the bottom left corner doesn't work anymore. I then have to ctrl+alt+del and sign out then sign in again then things magically go back to normal. Does/has this happen/happened to you? Thx in advance!
I only want to make my scroll bars wider. I don't wanna change anything else because I messed with it enough and have it just the way I like it. Is there a way please?
I have a few issues with a brand new Asus Transformer T100 running Windows 8.1. 1) I don't know what this Red X means. 39952 2) My T100 won't automatically connect. I have it checked to join the network automatically, which leads to another issue. When it doesn't automatically connect, I...
... and I don't need to upgrade to Quickbooks, et al. nor invest all that time into something new - even if it might last forever (= 3 years in MS terms) nor LOSE important business data back to 1994 that is used weekly as reminders, financial usage, reports, annual IRS, other tax tracking,...
There seems to be almost no correlation to performance - 5 bars could be a 100+ Mbps connection, or it could be < 5 Mbps... On the other hand, 4, 3, 2, and 1 bars all mean that the connection is going to be flaky and unstable :rolleyes:
WMP 12 Black Border (Bars) in General Support
Hi in WMP 12 when watching a video I get a small black bonder (bars) of about4 mm around all sides. It happens in fullscreen on both 16:9 and 4:3 videos. I have the video resolution on Windows set to 1080p @60hz and In Windows Media Center it's set to 1080p @50hz. It does the same for 60 50...
