Dolby advanced audio disappeared from my acer v5 notebook
Laura
I was trying to fix a problem, and then I removed some programs, and I think i accidentally removed a file that is needed for the dolby. Now I can´t open it, and when I try it says that I could re-install it. But how?
If you have an available System Restore point that is BEFORE whatever you did, that should get it back (the "problem" will also be back after the system restore).
If you don't have a system restore point (and you should), check the PC vendor's downloads, in this case Acer, and get what you need.
My acer laptop has a program called "Acer Recovery Management". It allows you to re-install the drivers and applications that came with the PC. I was going to suggest that you look for it on your computer, but when I look at mine the Dolby software is missing. Still might be worth a look see on your computer.
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
