No audio everytime after wake from sleep
    Windows 8 x64 Home Edition & Windows 7 x64 Professional
    I am on a hp g70-457ca, running the latest updated version of Conexant High Definition SmartAudio 221.
    And after I close the lid on battery and it goes to sleep, and I reopen, there is no more audio until I restart.
    I am running windows 8.1 pro.
    Can anyone please help me out or point me in the right direction.
    Same problem, same os, on a hp envy15j000... Also no idea why this is happening.
    Quote Originally Posted by Wardboyd View Post
    I still havent found a solution.
Hello Eight Forums, New HP Notebook. One month power on. W8.1 64bit Setup with Classic Shell and Fast Startup Off Have to decide next week. If I should return for new machine exchange or keep with two known issues. 1) Sleeps on timer okay. Just cannot wake from Sleep. Tap space...
My box is windows 8.1 enterprize x64, and I got a problem that don't wake up from sleep. I attached three screenshots of event viewer. And for other informations you need, please explain and specify easily so that I can make it, and please understood I am not an expert. Thanks in advance.
BSOD After Wake from Sleep in BSOD Crashes and Debugging
I am randomly facing a BSOD when my PC wakes from sleep. This usually happens when Windows goes to sleep automatically and then I try to wake it after a while. However when I put my PC into sleep manually I don't face the issue when it resumes again. I really appreciate if someone can help me...
I try hitting the power button, nothing. I have to restart, it takes a long time to read the hd's in bios, then when it restarts there is no network connection, so I need to restart again. no real pattern to this, sometimes I leave the machine on all night and no problems, other times just a...
Hi, I have a rather weird problem since installing win 8. When the computer goes to sleep, my normal practice is to hit the esc key to wake it. Worked fine on win 7. Now, when the computer goes to sleep, I hit esc and the computer wakes up but only for about a second or two and then it goes...
Hi! I've a clevo m570MU laptop and I've intalled windows 8 x64, dual booting (with windows 7 x64 on the other internal disk partition). Everything is fine with windows 8 but I cannot get it to hibernate. I've read that it could be the "ENE SD card drivers" and so I uninstalled it. Also, that...
