My Headsets sound keep cuting out
    I have been having a problem with listening to audio through my Headset as it continuously keeps cutting out. This problem happens with all of my headphones and headsets but doesn't affect my speakers. Audio will work normally then suddenly stop after unplug the headphone they work again. Any help would be appreciated
    While fiddling around I noticed something interesting whenever the sound cuts out under speaker properties it says "The device you are configuring has been removed."
    As this is apparently only a problem with the headsets, it would appear to be a flakey (bad) front panel headphone jack or assembly.
    Since you have a custom desktop, try to troubleshoot the front panel headphone jack and assembly. I've had several problems with front panels on custom systems.
Bluetooth headsets not being found in Drivers & Hardware
I have two headsets that I've used in the past with ps3, 3 win7 laptops and my iphone with no issues and are still working fine but win8 cant discover them however its finding my ps3, xbox and a cellphone Connecting the headsets to the computer with usb shows the devices names but no drivers...
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
