Solved No Sound through HDMI...connection is now unplugged!!¬
tonewheelkev
Just when all was going well....system has decided that my HDMI connection...hitherto without problems
....is now 'unplugged'....and no matter what I do (reboot..switch devices on/off)....I now have no HDMI connection
Well...VIDEO is present....but NO SOUND
I've just wasted an hour trying to get this going...any thoughts please???
    Windows 8 Pro 64-bit (6.2, Build 9200)
    Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz (2 CPUs), ~3.3GHz
    Asus P8Z68 - VLX
    8192MB RAM
    NVIDIA GeForce GT 430
    Samsung BX2231
    ADATA SSD S510 120GB (O/S)
    Seagate 2TB (ST2000DM001-9YN164)
    WD 1TB (WD10EARS-00MVWB0)
    Seagate 500GB (ST500DM002-1BD142)
    OCZ - ZS550W
    Chrome
    Comodo
Must be more specific.Is this to a HD tv?
Right-click the volume control icon on the bottom taskbar and click on Playback Devices to open the pop-up window for sound options. In the Playback tab, select Digital Output Device or HDMI as the default device, click Set Default and click OK to save the changes.
In the Video cards control panel may have to check for the settings for HDMI connection for audio.Need more info on what your doing exactly.
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
Please fill in the "My System Spec". We have no idea what hardware you have.
HDMI audio can be generated from two places, in most cases. Either via a separate sound chip in the video card or via S/PDIF connection to the motherboard. Most modern systems have the sound chip on the video card.
HDMI is the correct "default playback device" for HDMI audio.
if it's the specs that I see in your profile then go into your nvidia control panel and disable hd audio then re enable it. make sure you hit apply for both times. happens to me when i sometimes have my second screen off for a couple days as it is used for mainly movies with hd audio to my AVAMP. this is with my thought that you are using your GT 430 for audio of course.
    WIN 7 PRO x64, WIN 8.1 PRO x64
    Custom
    Intel i7 4790K
    ASUS Maximus VI Extreme
    32GB(4x8GB) DDR3 Team Xtreem 2666 @ 2400 CL10 10-12-12-31
    2x MSI GTX 780 Twin Frozr OC 3GB
    ASUS Xonar Essence STX
    ASUS PB278Q, HP 2311xi, UN46F7100AFXZA
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    10TB RAID 0 Array (Movies, Steam)
    6TB RAID 1 Array (Backups, Documents)
    3TB EXT Drive (Secure Backups)
    Corsair AX760
    NZXT White Switch 810
    Block: XSPC Raystorm, RES/Pump: XSPC Bay res W/D5 Vario, RAD: XSPC RX360, 6xNF-F12's
    Rosewill RK-9000 with MX Blue switches Logitech G15 Rev 2 (gutted for LCD)
    Logitech G400
    Chrome
    I also own a Lenovo Y510p, and Yoga 2 Pro
Thanks fellas....wasn't aware that anyone had come back to me on this one!
I'll make sure I have my 'reply to thread' alerts adjusted suitably in my profile:)
Problem was corrected when I installed NVIDIA driver update....so running normally now.
Many thanks
Kev
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
good to hear
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
