Add Sound Enhancements to Windows 8
Bgeo99
Intermediate Poster
New York
Hi.
I was wondering if it's possible to get sound enhancements on a computer that doesn't have them built in. What I mean by this is when you go to Volume Mixer > (click the audio device) > Enhancements tab, you see things like Bass Boost and Pitch Shift. If a computer doesn't have these options, can I get them to work in order to change the pitch, for example? If it can't be done, what third party application can I use to change the pitch of the audio coming out of the speaker so everything sounds squeaky? Is there a program or setting that does that? Also, the computer had Beats Audio with Beats Audio Control Panel.
    ASUS Q500A
    Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz (4 CPUs)
    6144MB (6.0 GB DDR3) RAM
    Intel(R) HD Graphics 4000
    Realtek High Definition Audio & Intel Display Audio
    1366 x 768
    Microsoft Wireless Mobile Mouse 3000
    Mozilla Firefox 34.0
    Kaspersky Internet Security 2013
Most multimedia players have their own settings for sound, did you try thru them ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
According to what I can find (and its sketchy) this has "Intel Panther Point PCH - High Definition Audio Controller". Nowhere do I find that this comes with the Beats Audio. The only Beats Audio I can find is what comes with certain model HP computers.
Assuming the Intel audio is correct, unless Intel has an updated driver with audio enhancements, you may be out of luck.
I know that the ASUS laptops don't come with Beats Audio. I'm talking about a different computer than mine and it is a new HP laptop. What was different is that it has Beats Audio. Usually, to increase the pitch or do some other enhancement to the sound, you can do what I said above or access the Realtek HD Audio Manager via Control Panel > Hardware & Sound and change the Karaoke setting under enhancements. However, the Beats Audio computer has a Beats Audio Control Panel that does not contain enhancements/effects at all, and I really want them for the HP computer.
So, would it help to install Realtek audio drivers and then maybe the enhancements will come up, or will it affect the existing drivers? Should I uninstall the Beats Drivers first in order to switch to Realtek or am I really stuck with the default boring audio drivers that don't have nice effects that Realtek provides?
    ASUS Q500A
    1366 x 768
I don't know if this is what you are looking for or not.
See picture:
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
You can't install RealTek drivers if you do not have a RealTek audio chip in the PC. You can only install the drivers from the actual chip vendor (or from PC vendor for the specific chip), or the generic basic function Windows HD Audio Codec. However, the Windows HD Audio Codec does not have any sound enhancements.
There are several software add ons such as the Beats Audio. Creative has a SoundBlaster MB software enhancement which is similar to the Beats. A quick google search doesn't turn up any 3rd party add on for what you want.
Any HP Beats Audio laptop would need the HP audio drivers from their site. I believe that HP uses IDT audio for a lot of their laptops.
    Self built
    Intel Core i7-4790
    GA-Z87X-D3H
    G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNT
    Sapphire ATI Radeon R7 250
    Realtek ALC892
    Samsung UN32EH5000, Dell 1703FPT
    WD5003AZEX
    WD10EZEX
    Samsung HD103SJ
    Samsung 128 GB 840 PRO
    SeaSonic M12II SS-500GM
    Fractal Design Define R4
    Zalman CNPS9900ALED
    Logitech K800
    Logitech M705
    16 Mbps
    Avast
    Bose Companion 2 Multimedia Speakers
See picture:
Yes that is what I am looking at and on one computer I see Enhancements, which is what I am looking for, but the second computer has "Tone Controls" in instead.. I want a way to get the enhancements there somehow.
    ASUS Q500A
    1366 x 768
Hi. Which audio drivers exactly? Would it help if I downloaded the IDT High-Definition (HD) Audio Driver for Microsoft Windows 7 and Windows 8 from HP.com? Here is the link: http://bit.ly/17FMarl
I'm wondering maybe this will add the enhancements through the installation, or is it just for some fixes?
I also found this:
http://bit.ly/IaL7q3
HP doesn't specify what each driver installation is for, so I'm confused by their website. Somebody help..
    ASUS Q500A
    1366 x 768
See picture:
Maybe go to WalMart & get a cheap set of Logitech speakers or headset.
My headphones (with microphone) are Logitech.
Plug them into the second computer & see if you get the enhancements available.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
If the enhancements are not there in the PC already, a headset is not going to provide any audio enhancements.
I have 2 headsets.
Realtek & Logitech.
Each shows different enhancements:
If the enhancements are not there, why do the 2 different brands show their own different enhancements ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
These are not the standard analog headsets. I didn't know USB headsets had that.
I have the same problem(hp/speakers:realtek hd audio), Sony Vaio with Windows 8.1 x64. I have the enhancements tab, but there is only choice :"reset all enhancements". But there are no enhancements :) Does it means that there is no chance to get them?
    windows 8.1 home premium
    Sony Vaio
    Intel Core i7 3632QM
    8GB
    2GB AMD Radeon HD 7650QM
    1 TB
Ha, managed that. After trying a dozen of realtek drivers(one designed for lenovo worked with few enhancement options) I used microsoft driver which gave a wide range of options, including EQ,pitch, environment,etc
    Sony Vaio
    8GB
    1 TB
Do have the download link? :D
    ASUS Q500A
    1366 x 768
I can backup current one and share it if you still need it
    Sony Vaio
    8GB
    1 TB
    ASUS Q500A
    1366 x 768
    Sony Vaio
    8GB
    1 TB
