Sounds cuts out after a couple minutes, I pause then ok?
    Windows 8.1, Toshiba Satellite L745
    It was originally windows 7, then I upgrade to 8, then the 8.1 preview evaluation copy. I think I started having sound issues when I went to 8.1. I will play for a couple minutes then cut out. If I pause for a few seconds then play the sound works for a few more minutes. The sound works fine when I'm using HDMI to the television or on headset. Could there be a hardware/motherboard issue since it's the speakers that are cutting out? Could it be an 8.1 issue? Thanks for your help
    Could be 8.1. 8.1 has caused some audio systems to stop working or be intermittent. Check Toshiba for any updated 8.1 drivers and if there is none, reinstall the Win 7/8 available driver from Toshiba.
    HDMI is different and either the HDMI has its own "sound card" or it uses S/PDIF digital connection and not the actual PC's sound card.
    Thanks Fireberd,
    I just updated to the actual 8.1 from preview and it still does it. I think I tried updated drivers, but I'll check. Maybe they didn't have them for windows 8 or 8.1 when I checked.
Just set up my new Dell 660 desktop and noticed that with Windows Default sounds that the "navigation compete" sound effect and some others don't seem to be working. That one sound I mention is the familiar sound you get when using IE and clicking the mouse to navigate around the web pages but...
My copy of Windows 8.1.1 x64 works very well, as does my computer in general. When I restart my computer, it has no video signal for about 60 seconds and then the OEM (Dell) splash screen appears and booting proceeds normally. I can tell there's no video signal because my monitor displays a...
How to Sync, Pause syncing, and Resume syncing OneDrive Files in Windows 8.1 OneDrive syncs the files from your online OneDrive with your OneDrive folder in Windows 8.1 to keep them both updated. This tutorial will show you different ways on how to sync, pause syncing of an in-progress...
WIN8 Security Pause in System Security
I have WIN7. I have a friend in Denmark that has WIN8. I sent him a program that I have been running for years on XP and WIN7 that has no viruses. He tries to run the install exe and gets some warning that Windows thinks the program is suspicious and refuses to run it. He tried to install it as...
Hello. I recently bought a new desktop PC. I've had it a few weeks and for some reason I've recently been having trouble with the wireless. I can verify that the problem is with the computer, as my old laptop, my phone, and other devices all seem to be doing fine and don't experience the same...
Hello, I have a new windows 8 laptop and every couple of minutes the internet connection goes to "limited" and if I simply disconnect and reconnect from the network it starts working again, but then disconnects again in about 5-10 minutes. This is extremely annoying and none of our Windows 7...
Hi all, Ever since I have downloaded Win8 Build 8250 my audio has gone weird. If I pause a song in iTunes or a video for more than about 4 minutes then when I try to replay the song there is no audio. The only way to get the audio back is to restart the program. I have encountered the problem in...
