I used to have a sound system that ran from my sound card but it doesn't seem to be anywhere, here is what I have under "sound" in Device Manager My system Windows 8 IE10
Can you be more specific on exactly what your problem is? If you have the VIA and its set as the default audio playback device the sound should be working.
I do have audio as mentioned I was just confused that I used to have AC97 which doesn't appear to exist anymore, I was just interested as to why it disappeared.
Hi Can SOMEONE PLEASE HELP me I have TOSHIBA and My AUDIO worked about a month ago and I am a student I need my Audio to work yet it says my adio is turned off in WINDOWS O_@ I don't understand then it tells me I have no sound device I NEED SOUND Uggg
