8.1 sound problems
    windows 8.1
    8.1 sound problems
    Updated to 8.1 and had the dolby problem like everyone. I am not that good with these new fangled machines but how do I fix this problem. The sound is now terrible and I have it all the way to the top and can barely hear anything. Is there a fix that is available or do I need to go back to regular 8 and if so how do I do that. Thanks.
    Is a Lenovo laptop.
    Southern California
    Windows 8.1 Pro with Media Center x64
    welcome to the forums mate.
    First off, you'll need to let us know what kind of laptop you have (so we can direct you to the correct driver). You may need to simply update the drivers for it, to the newest 8.1 audio drivers. Check windows update for any other fixes - that may also help.
    windows 8.1
    Thanks for that. I am not sure how to tell what it is. Has an intel core I3. I will try the window update. I not a very good techy but I try anyway lol.
    Is a Lenovo laptop.
    If you provide your Lenovo specific make/model number, someone can help you find the correct drivers.
    windows 8.1
    Ok I found the box.
    2.5G
    4G ram
    Lenovo G580
    model name 20150. IF you need something else I can probly find it.
    windows 8.1
    I think it is related to the dolby problem as I still get that message when I start up in the morning or after restart. I found the dolby program in the programs list and tried "repair" a few times but it didn't help.
    Quote Originally Posted by desdem12 View Post
    Ok I found the box.
    2.5G
    4G ram
    Lenovo G580
    I have to go out for a bit but someone should be able to help you now.
    Good luck,
    my2cents
    Southern California
    All righty, that's perfect. This is the audio driver for your Lenovo G580 computer (clicking the link will ask to download the driver): http://download.lenovo.com/consumer/...s/au200w81.exe
    it is for the Conexant Audio Driver for Windows 8.1(32-bit OR 64-bit) - IdeaPad G480 lenovo
    windows 8.1
    Thanks guys.
    Southern California
    You're welcome. Did it work? Any more problems?
    You may need to update all the drivers (because down the road they all might give you problems). Lenovo makes spotting the correct driver very difficult. You might see if you can go to the support page of the Lenovo website and download a driver detection tool, if the offer it.
Page 1 of 2 12 LastLast
8.1 sound problems
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Hello everyone, First of all, this is my first post on the Windows 8 forums, I've had this laptop for 3 weeks now and for the most part, I'm starting to get used to 8.1. However, there are still a few problems that make me feel terribly powerless. For one, whenever I plug in my headphones,...
Hi I'm using Windows 8 with the Media Centre plug-in. My problem: After watching live TV (Satellite using TBS 6981 card) for a few minutes, the sound starts to stutter and gradually gets worse until there is no sound. If I simply go up or down a channel, the sound is fine, then it starts to...
Solved Problems with Sound in Sound & Audio
Okay, starting from the more recent beginning, I decided to upgrade my computer. I installed a new gpu and cpu successfully, but failed to correctly install the power supply. While trying to start the power supply, it shorted and fried my hard drive. After a few painful weeks with best buy, they...
Hi I just downloaded and installed Windows 8 Consumer Preview Evaluation Copy Build 8250. I had no problems during installation and everything was OK. Like many other Windows 7 users I just have to get used to the missing start-button :D I know that the Consumer Preview is no final...
