8.1 sound problems
  1. #11
    windows 8.1
    I checked lenovos sight and they had nothing on it. I did see a detection tool though somewhere. I haven't tried it yet
  2. #12
    Southern California
    Windows 8.1 Pro with Media Center x64
    Might help you out with the other stuff. Good luck mate,
    Take Care
Page 2 of 2 FirstFirst 12
8.1 sound problems
So, I was playing a game and then suddenly my sound dropped. After it happened I tried restarting my computer and nothing happened. So now when I put my sound on 100 it sounds like 35. Can someone please tell me how to fix this, thanks.
Windows 8 When I record sound from CD, Website etc. (with Audacity or other software) it records the sound via the computers loudspeaker and from that via the computers microphone. But I want to record the sound directly from the sound card (or whatever it is). I know its possible, I have done...
Hello everyone, First of all, this is my first post on the Windows 8 forums, I've had this laptop for 3 weeks now and for the most part, I'm starting to get used to 8.1. However, there are still a few problems that make me feel terribly powerless. For one, whenever I plug in my headphones,...
Hi I'm using Windows 8 with the Media Centre plug-in. My problem: After watching live TV (Satellite using TBS 6981 card) for a few minutes, the sound starts to stutter and gradually gets worse until there is no sound. If I simply go up or down a channel, the sound is fine, then it starts to...
Solved Problems with Sound in Sound & Audio
Okay, starting from the more recent beginning, I decided to upgrade my computer. I installed a new gpu and cpu successfully, but failed to correctly install the power supply. While trying to start the power supply, it shorted and fried my hard drive. After a few painful weeks with best buy, they...
Hi I just downloaded and installed Windows 8 Consumer Preview Evaluation Copy Build 8250. I had no problems during installation and everything was OK. Like many other Windows 7 users I just have to get used to the missing start-button :D I know that the Consumer Preview is no final...
