Missing audio converter win8
    Firstly I couldn't see this posted previously so pls forgive if it is....
    I used to have a handy audio format converter on a taskbar at top of page, however it disappeared and I can't find it anywhere, any ideas ????
    Thanks in advance for help
    Hello, iknownuffin70. How have you been?
    Search for it in All apps or just start typing on the Start Screen. Right-click should give you the option to pin to taskbar.
    Hi Hippsiegypsie, Thanks for asking...As it happens I have been unwell for a while, then some family matters to take care of, so I have not been active on the pute for a while...... Unfortunately, your suggestion didn't have an option to re install a audio converter, I extended and checked all the drop downs that ensued. I also could not see any program in "All Apps" search. Nonetheless I appreciate your suggestion...It seems to me that many win8 systems are somewhat different to one another.
    Thanks anyway, and keep well.
I am fairly sure I had this manager when I started with windows 8 . I have also done a clean reinstall after hard drive crash. it shows the in and out sockets on the back of the board(gegabyte GA-970A-DP3) AND ALOWS ME TO RE ASIGN THEM.. Can any one tel me how to get it back. very greatfull for...
I have alot of mp4 music videos that I would like to convert to wav or flac. Can anyone recommend the best software for doing this on windows 8?
Hi I need help, can't find a solution and this is slowly driving me crazy... I installed the realtek drivers and they appear as installed in the control panel but it does not show up at the start up of windows, I have tried installing the latest drivers from realtek official page and the lates...
Hello My MB has ALC898 audio chip. Should I stay with the default Windows 8.1 HD audio or install the driver from Realtek (which is R2.71 the latest version) My system is used for gaming BTW. Thanks.
Audio Converter in Software and Apps
Guys, I was looking for a free audio converter and finaly i got it from softpedia.As usual, i checked it with online virus total scan and confirmed that its not harmful in anyway.But when i installed it (the whole process looked suspicious) it gave me error ("app is not responding") and didnt start...
I have a PC built from an Asus P5B-WiFi Delux motherboard running Windows 8 Pro with Classic Shell which has an Realtek HD audio on board sound device. I also have a Creative X-Fi Gamer sound card installed. All of these were installed and working correctly. One time I unplugged my speakers...
