Missing audio converter win8
iknownuffin70
Brisbane Queensland Australia
Firstly I couldn't see this posted previously so pls forgive if it is....
I used to have a handy audio format converter on a taskbar at top of page, however it disappeared and I can't find it anywhere, any ideas ????
Thanks in advance for help
    Leader
    intel core i5-3570cpu@3.40GHz
    8 GB
    nvidia
    IE
    AVG
Hello, iknownuffin70. How have you been?
Search for it in All apps or just start typing on the Start Screen. Right-click should give you the option to pin to taskbar.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
Hi Hippsiegypsie, Thanks for asking...As it happens I have been unwell for a while, then some family matters to take care of, so I have not been active on the pute for a while...... Unfortunately, your suggestion didn't have an option to re install a audio converter, I extended and checked all the drop downs that ensued. I also could not see any program in "All Apps" search. Nonetheless I appreciate your suggestion...It seems to me that many win8 systems are somewhat different to one another.
Thanks anyway, and keep well.
    Leader
    8 GB
    nvidia
    IE
    AVG
