Audio Recording Issues
    Widows 8.1
    I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1
    I am having one problem, most likely user error.
    When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very little bass) I also have the same problem with the audio on a screen recording program, Bandicam, when recording youtube, or an MPORG.
    I've tried various applications to play the audio/video , with the same result. I'm not recording through the built -in mic, I checked.
    An imported audio file, from my Win 7 desktop sounds fine, and an audio file recorded on the laptop, still sounds "tinny", on the desktop.
    Does anyone have any ideas ? I'm reasonably sure, it's a setting I need to fix.
    There have a few reports of problems with sound in 8.1 and even some recording issues due to drivers needing update. I have a recording studio and see problem posts of needing updated drivers for many recording studio devices. I have a Roland Octa-Capture USB connected recording interface unit and Roland issued an update for 8.1.
    Whether this is your problem? Did it work OK before installing 8.1? If it did, reinstall the ASUS supplied driver for your PC.
    Have you tried recoring something with the built in mic or a line in, to see how that is?
    Widows 8.1
    Thanks for replying!
    Just tried recording my voice with the built in mic... which already never sounds the same, when recorded. As for pre-8.1, had the machine 2 days before it came out, and never tried recording with 8.0. I'll give the built in mic some more attention, to compare sound quality.
Okay, let me flat out start with, I can NOT stand to use windows 8.1. I am very familiar with W7 and XP but windows 8 just looks, and feels like it was made for a 9 year old who out grew his tablet. I have had this machine for about 3 months now.... I honestly do not enjoy using it...
Looking for a audio recorder/grabber to record audio that i play from my computer.. believe it or not, i used to be a mac user and used programs like audio hijack and etc.. now i'm with windows 8.1 and what the heck do i use to grab high quality audio and save it to high quality files on my...
USB Audio Issues in Sound & Audio
I have a Blue Tiki USB microphone. But the audio input is very low and i went to the sound settings and turned it up and it made no difference, The boost microphone slider was missing, i also turned the sensitivity in beats audio ADWare than came with the laptop because my laptop has beats...
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
Realtek audio issues in Sound & Audio
So I've been having issues with the Realtek HD audio drivers on my Sony VAIO laptop (model number VPCCW21FX). No matter what version of Windows I use (Windows 7 or 8), the Realtek Audio Manager will not open. Currently, I am running Windows 8.1 x86 on my laptop. Before, I was using the Microsoft...
Hi as the title suggested I am new here. Usually I like to contribute before asking too many questions but I come in a time of need. I will explain my issue: I am using a Windows 8 (64bit) Samsung NP350V5C-A08UK. Yesterday I plugged in a pair of apple headphones(with the mic) straight...
