Quote Originally Posted by Nemix View Post
Go into Control Panel > Program and Features and uninstall the Conexant Audio Driver, reboot.
Go into Control Panel > Device Manager expand Sound, video and game controllers...right click on Conexant Audio Device and uninstall, check mark Delete the driver software for the device and click OK, reboot.
Download the following updated Conexant Audio Driver for Windows 8.1 (choose the one with date 25/9/13): Station-Drivers - Conexant
Once you the new audio driver downloaded, navigate to the download folder and extract the downloaded file and install the new audio driver, reboot.
Download the following Dolby driver for Windows 8.1: PCEE4
Once you have Dolby downloaded, navigate to the download folder and extract the downloaded file then install the Dolby version for your laptop (Advanced Audio or Home Theater), reboot and all done!
Please give a reputation if this worked for you because I had to create a Mediafire account just to try and resolve this issue since I know how frustrating it can get to not have features that originally came with your computer not working correctly in Windows 8/8.1.
Running the installer from this gives the same "PCEE needs to be installed" error. So I don't know how it should help.
By the way. WTF is PCEE? and where do I get it from?
