Query on Optical S/PDIF audio connection
  1. #11
    Windows 8 64 bit
    thanks a lot for the clarification mate...appreciate all your help.
  2. #12
    Windows 8 64 bit
    @fireberd>> sorry for reopening this thread..please check the below snapshot
    please tell me why the DTS option is disabled at my end? Thanks.
  3. #13
    I don't know why its not enabled. I would reinstall the software, from ASUS, and see if that helps. I have no information on that.
  4. #14
    Windows 8 64 bit
    ok...no issues..will check on that one..thank you.
  5. #15
    Windows 8 64 bit
    @fireberd>> Request you to check the below 2 links:-
    F&D F6000U | Best 5.1 Speakers | Best Laptop Speakers in India
    F&D F6000 | 5.1 Speaker Systems | Best Speakers for Home Theater
    After checking the specifications of both, please let me know that out of F6000 and F6000U, which is the better in terms of sound quality, more deep bass etc?
    I understand that F6000U comes with FM+ USB Card reader but I can live without that, I am just looking for heart thumping bass.
    Please also check F&D F5019 | 5.1 Speakers for PC | Best Multimedia Speakers in India
    Thanks in advance.
  6. #16
    All three systems are intended for specific uses or interfaces. Can't really compare them. The Laptop speakers are designed for a laptop PC. The Home Theater speakers are designed for more than just PC sound. The 5.1 speakers for PC are designed for a PC system but use the Analog output of the PC's sound card.
    Without actually hearing the systems, its a "guess" on what would be better. Sorry.
  7. #17
    Windows 8 64 bit
    I understand that but how about when you compare them in terms of their total RMS, frequency response, sub-woofer size etc?
  8. #18
    You can do the comparison just as well as I can, by reading the specifications of each unit.
    I'll be off-line most of the day so I won't be able to look at those devices until possibly tomorrow. I have a full day scheduled in my recording studio.
  9. #19
    Windows 8 64 bit
    that's okay, I have absolutely no hurry..please take your time and come back with your feedback, thanks.
  10. #20
    If I were to pick one for my PC from the listed 3, I would select this one, just based on what is posted on the site, not based on actually hearing the systems.
    I would still want to hear them before I actually purchased anything. I could be totally wrong after actually hearing them.
Query re Blu tooth in Drivers & Hardware
I have a Toshiba Satelitte L550 running 8.1 in 7 style and have just bought a Gigabyte M7700B laser tracking Blu tooth mouse. Now I used the Blu tooth set up for the machine but it finds no device. In Device Manager I see the Blu tooh connection has a yellow triangle. Now I have downloaded the Blu...
Query re pictures in General Support
I have a query on how to make my pictures shown in order like they do in my 7 machines. When I open the SD card and pick a picture it goes straight to paint and I have to close that picture before going to another shot. In 7 one used to be able to hit the > button and the next picture would come...
Blu-ray Optical to TV/Xbox 360 in Drivers & Hardware
Is it possible? THAT is the real question.. I've been researching a ton online and can't seem to find anything that I can get that will allow this. I have Windows 8.1 OEM and I can stream any video I want that's already downloaded to my computer using the video app and my xbox 360's use of Play...
Hello, Does anyone have or know where I can purchase an ASUS S/PDIF-SA 4-1 Digital Audio Out Bracket? I've looked all over the internet, but can't find anyplace or anyone selling them anymore. I need it to compliment my ASUS motherboard. It allows for playback out of both Digital Out's...
Quick query in Installation & Setup
I have two machines I upgraded from 7 to 8 at about the same time within a week of each other. Now yesterday I had a pop up message from Microsoft to say that I could download / upgrade to the 8.1 for free. So I checked the site and it was genuine so downloaded and installed the 8.1 and reinstated...
Optical Splitter in Sound & Audio
Hello, I have a splitter that connects my XBOX360 and my Windows 8 desktop computer to my amplifier. However, when I have both my XBOX and Computer on, the sound does not work. The solution is that I turn off my computer whenever I want to use the Xbox. This fixes the problem because it...
Quick query in Software and Apps
Just downloaded an Adobe based manual and it was so small to read properly and I couldn't find any way of increasing the size of the pages. Is there an easy way of doing this. While I am on the subject when I went back to the desktop I couldn't find my way back to the document not a big deal...
