HD audio driver not working properly
    In my HP Compaq Presario V3000 Laptop with Windows 8.1(32 bit) version, when I play a video such as Youtube, I do not receive any audio although video is played.But Device manager shows the message for 'Sound audio contoller' as 'HD audio driver working properly'. But if I disable Sound/Video Controller and then enable it, the audio comes back properly. But my problem is that every time I open the computer, I have to do this exercise if I wish to watch aan audio/video bit! Pl advise.
    If the sound problem is ONLY with YouTube, install the latest Adobe Flash player and see if that fixes it. YouTube uses the Adobe Flash and it has been known to cause the problem you have.
    Thank you, Fireberd. The problem is not exclusive to YouTube, but concerns all audio files too. I have this problem from the time I started using Windows 8 and now it continues with 8.1 too!
    This is an old PC, and only supported up to Vista by HP. Windows 8.1 is having some audio issues with many systems, that worked OK with Windows 8. Have you tried installing the Vista driver in a Vista compatibility mode?
    I have a recording studio and had to update the Roland drivers for my recording interface unit to be Windows 8.1 compatible, the previous driver which supported Windows 8 was not compatible.
    I shall try that, Fireberd. And then I shall report the result. Thanks
I updated to 8.1 because supposedly, it was to offer features similar to win 7. Instead, it's even worse than win 8. Now, the sound quality on my laptop is lousy because the Dolby Audio driver receives an error message and isn't working. I went to Lenovo (I have a Ideapad N Series 580) and...
Hello, I recently got a set of 2.1 HiVi Swan M-10 speakers and hooked them up to my laptop until I can finish my build. When I first hooked them into my E55-A Toshiba Satellite the bass wasnt coming from the sub in fact it was combining into my L/R speakers making them sound terrible. A quick...
Problem: My laptop with OS Windows 8 will become no sound frequently. I try to find out the cause, and discover that the device is being used by another application, but I can't find any application using it, here is the screenshot: 47290 47291 Under this situation, when I open Window Media...
For the past few days my laptop, a Windows 8 Samsung model with Intel core i5, has been acting up for the first time since I purchased it last year. I've been away on vacation for three weeks, and have not used it during that period, so when I returned the system naturally installed itself with new...
Intel® WiUSB USB-IFxHCI USB Host Controller driver is not working properly as there is the yellow hazard(or whatever)sign in device management...,how do i get this driver ?my laptop is a dell inspiron 15r?
I like to use the Alt+f4 key for closing various windows.It used to work fine until suddenly the alt+f4 key just doesnt do anything in the browser window and in folders its opens the preview pane.How do i set it up to close the current window as it was always??? Thanks in advance.
