Streaming to surround sound
  1. #11
    Hafnarfjörður IS
    Quote Originally Posted by dakeb View Post
    Skifta is great, easy to use, but it only streams stored content, not cloud.
    Hi there
    Now I'm confused -- things like iTunes will work fine so too will audio -- services like Tunein for playing Internet radio - and Wi-fi-ing to remote screen should work just fine. ITunes don't require you to download anything just to PLAY a song - assuming your subscription level is relevant.
    Whatever Cloud video service you use IT JUST HAS TO access the content via some sort of "PLAY" mechanism -- the result of the play is echoed to your remote screen - you don't have to store the content as a file before playing.
    What is the Cloud service you are trying to access -- if things like Sky GO and NETFLIX work OK then your cloud server must presumably also have some type of "PLAYER APP". For example watching a live football match via SKY GO doesn't require me to download any content - I just "share" the phone screen with the TV via the Samsung piece of kit -- SKY GO disables the HDMI out cable on the phone !!!! (Bar Stewards !!!!).
    Cheers
    jimbo
  2. #12
    Skifta seems to require you to locate a source, then a file, then an output device, then it plays that file only.
    maybe I am doing something wrong, but if I play tracks using Spotify how would I get Skifta to transmit them?
    (this is on the Skifta phone application - I didn't try it on the Laptop yet)
  3. #13
    Hafnarfjörður IS
    Hi there
    if you are playing SPOTIFY etc on the phone then either by using the HDMI adapter or better the WI-FI adapter you enable the Phone (SAMSUNG) to "Share the screen" and the video + Audio is Wi-Fi transmitted to your TV via the Wi-Fi adapter (that piece of kit I mentioned previously in this thread).
    SPOTIFY Works fine like this -- audio output straight from TV into surround system.
    You RUN the application ON THE PHONE simply mirroring your screen to the Wifi device and hence the TV.
    (If your TV has Blue tooth and you only want audio then that's easy too - audio goes direct to blue tooth device - although for top quality audio blue tooth isn't that good --it's OK for typical compressed mp3 files from iTunes or internet radio quality).
    Cheers
    jimbo
Page 2 of 2 FirstFirst 12
So here's my problem When I watch YouTube videos I get random stutters where the sound skips. The image doesn't seem to freeze though, just the sound I also get issues with the sound streaming music online, where it pauses for a second and stutters even though it's not buffering. When this...
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
Here is my setup: Motherboard: P8Z77-V LE PPLUS Processor: i5-2300 Source: Onboard Graphics/Audio (HDMI) Receiver: Harmon Kardon 2600 No matter what I do, Windows v8.1 will not play anything out of my Harmon_AVR HDMI source. I installed Windows 7 using the exact same setup and it works...
I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price. So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable -...
I have tried for some time now to get my surround sound to work on my Packard Bell Ixtreme X8540 since upgrading to Windows 8 via Microsoft's upgrade tool. When I had Vista installed, there was an icon on the bottom task bar which would take me to a control centre for the audio which gave the...
Since upgrading my HTPC to Win 8 Pro 64 bit I cannot hear my surround speakers anymore. When I do the speaker config, the sound that is supposed to come from my surrounds is instead coming from my front right and front left speakers. I am using a GTX 460 GPU as my sound card. I have the latest...
