Conexant AC-Link Audio
    windows8
    Hello,
    On my Hp Pavilion zd800 with sound card - hardware id PCI \ VEN_8086 & CC_0401 & DEV_266E and 64-bit Windows 8 it can not have audio. Has anyone had the same problem? Desperately Seeking a solution. thanks
    Can you provide the full vendor ID code per the example as shown below:
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_18497662&REV_1001
    You can right-click and copy it from the device manager:
    windows8
    Pci\ven_8086&dev_266e&subsys_3082103c&rev_03
    pci\ven_8086&dev_266e&subsys_3082103c
    pci\ven_8086&dev_266e&cc_040100
    I have the same problem with a CQ50-142US Laptop with windows 8.1 no sound same company drivers and they are in bankruptcy I hear.
    Quote Originally Posted by sandman View Post
    The only thing I can find (that might work) is listed as a download from Softpedia. Now, I normally would suggest you go directly to the manufacturer's site but it appears you can't do that anymore. Softpedia lists this driver as Win 8 x64 compatible with special installation instructions. You can try it if you like but do so at your own risk:
    Download Conexant AC-Link Audio Driver 6.14.10.671 for Windows XP 64 bit, Windows Vista 64 bit, Windows 7 64 bit, Windows 8 64 bit
    Good luck with your decision.
    windows8
    Thanks,
    i tried but does not work. Yellow triangle on Conexant AC-Link Audio. Error 10 device can not start
    Orbiting the Moon
    Windows 10 x64
    Quote Originally Posted by gattobuc View Post
    The string has to match entirely. Try the one from softpedia with add legacy hardware, just to make sure.
    Search on catalog.update.microsoft.com/ and get a few cab files. Install those through Device Manager. In some cases you have to add the driver with "add legacy hardware" extract the cab archive and then at "have disk" window point out an *.inf file.
    Good luck.
    windows8
So I have a Compaq Presario CQ60-210Tu And whenever I try Windows 8.1 or 8 32 bit the audio works fine but if I try 64 bit the audio just refuses to work. Any ideas? Typing this on tablet because my laptop is currently installing Windows 7 (I need sound for my schooling)
Issues with sound drivers not being digitally signed for 64 bit version for a CQ50-142US Notebook so went back to Windows 7 Enterprise 64 bit till final version comes out for this system. In my Google searches looks like quite a few people having same issues. No sound.Conexant High Definition sound.
