Front Audio panel not working on Windows 8.1
  1. #11
    Two things you can check.
    1. Enabled
    2. Front Panel Levels
  2. #12
    Windows 8.1 64-Bit
    It didn't work.
  3. #13
    Try driver R271
    Realtek
  4. #14
    Windows 8.1 64-Bit
    Does that mean that I would have to remove the Realtek Audio HD Manager?
  5. #15
    Windows 8.1 64-Bit
    It didn't work.
  6. #16
    Mr. S. and others have been doing a fine job of supporting you throughout this issue so there is very little for me to suggest; however, I did notice you installed that Realtek Audio Manager and I also noticed that your front panel headset option is not displaying either. That tells me that something may have come "coincidentally" loose inside your case. So, have you opened the case to ensure all connections to the front panel header are still secure? If so, I would tentatively recommend that you try uninstalling the Realtek Audio Manager and see if that fixes your issue because I also have the same chipset that could benefit from the R2.71 drivers; however, I decided not to install it because my audio worked perfectly (both front and back) with the drivers found during my Windows 8.1 Pro installation. Here's my screen for comparison:
    Good luck.
  7. #17
    Windows 8.1 64-Bit
    I just checked and the cable sits stable on the board
  8. #18
    Quote Originally Posted by SlimShady View Post
    OK, just wanted to be sure. Did you try uninstalling the Realtek Audio Manager completely and rebooting to see if your headset port is now being detected?
  9. #19
    One more thought, if you trying to configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver. However, if you are using anything less, then maybe you need to set that option to either 5.1 or just stereo (eg two speakers) to see if the front panel ports are now recognized as such.
  10. #20
    San Jose - California
    It just detects the rear sound card. As far as I know the front port uses the AC'97 version of the board that the case originally came with.
    I am not sure if this is correct. Normally, there are 2 connectors: AC'97 and HD Audio on the cable for front panel audio. I use the HD Audio Connector for all my PC's so you might want to double check the MB manual whether HD Audio Connector should be used instead.
Hi everyone.. I'm having a problem with my sound setup. I'm using Windows 8. I have a 2.1 channel speaker, headphone and microphone. On rear, I've connected my 2.1 channel speakers and on the front jack, I connect my headphones and microphone. The headphone works fine but Windows won't detect...
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out. I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty...
Hi, Iím having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesnít detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
