[Speakers Advanced Properties] sample rate and bit depth ?
    Windows 8 64 bits
    I have a Genius150 watt 5.1 speaker system Genius
    I dont have the realtek driver installed since the sound quality was not satisfying with it so I stayed to the default high definition audio device with stereo configuration.
    I have an integrated sound card. This is my motherboard model GIGABYTE - Motherboard - Socket 1155 - GA-P61-S3 (rev. 2.0)
    I want to know what sample rate and bit depth to choose for best quality playback at advanced speaker properties? The default ones are 16 bit , 44100 cd quality like you can see in the below image
    I dont understand what is that shared mode either.
    If I install again the realtek driver what should I choose then ?
    This is the best quality setting by default; however, you might want to try other settings based on your primary listening experience and do an audible compare:
    Here is more on the subject. Good luck.
    Playback audio format
    The "CD Quality" is more than adequate. There are higher modes, but won't really do anything other than make the CPU work harder.
    I have a recording studio (I use Sonar) and use 24 bit 44.1Khz for recording, only because it gives me more headroom, but when I mix down, its to 16 bit/44.1Khz.
    Windows 8 64 bits
    ok great thanks!
    Orbiting the Moon
    Windows 10 x64
    Good tip.
    Those higher modes are unhearable to the human ear. 44100Hz is already the double of the best 22000Hz a good ear can hear.
    If the built in driver works good enough keep it but the realtek one should be better in most cases.
    There are some realtek cards that work better if the drivers are installed (on some cards the built in driver may generate static noise in the background, in the speakers, heard when you don't listen to music)
Hello, Prior versions of Windows included sample photos, videos and music files from Microsoft. I have a new install of Windows 8 Home, 64 Bit OEM version and when I look in My Pictures, My Videos, and My Music these libraries are empty. In the past after installing Windows, I used these...
Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8 This tutorial will show you how to add or remove Advanced System Properties to the "My Computer" (Vista/Windows 7) or "This PC" (Windows 8) context menu for all users in Windows. ...
Hi all, I am organizing my mp3s using this pc with windows 8.1. For the columns so far I have the name, #, artists, album, type, size, bite rate, length, year, publisher, which is perfect so far, however, I also would like to add the sample rate of the mp3, however, I am unable to find the...
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
English is not my native tongue, I apologize for any misspells or similar in advance. I’m connected to a Konica Minolta C224 network multifunction printer. I have never had any similar issues with any other of my printers. Let me also say I work in traditional Desktop view. I have no...
someone please help me, am using the ATI Mobility Radeon HD 4200 Series (Engineering Sample - WDDM v1.1) on an hp pavilion g7-11767dx. i quite recently install the windows 8 release preview on it, but the problem is that, when i also installed fifa 12 on it, there were big black lines on the pitch,...
