Cannot record sound from websites
    Windows
    HELP!
    I have tried to record from a website with both Audacity and WavePad, but they can only record via the speakers, and of course this is not what I want - so how can I record directly??
    I may have some good new for you. Older versions of Audacity (v2.03) and earlier required a loopback cable to record streaming audio; however, Audacity v2.04 has added some new options that work perfectly without that cable. I just tested v2.04 portable and it worked like a charm recording (non-copyrighted) streaming audio from a website. You can download v2.04 here:
    Audacity: Windows
    And set you options like so and test:
    Good luck.
    Windows
    Quote Originally Posted by my2cents View Post
    Audacity: Windows
    Good luck.
    YOU ARE AN ANGEL!
    I was getting more and more desperate and had asked in almost all fora on the internet, so THANKS a lot.
    But I dont uinderstand it, for I have earlier used earlier versions of Audacity without problems.
    But thanks again
    Windows
    But now I got the next problem. Where do I adjust the record level
    Sorry I'm late with this reply but I wouldn't try to adjust the record level during recording because if it is too low, you may introduce distortion by increasing the amplitude. Conversely, if it is too high, you can always go back and adjust the levels in Audacity after the recording is completed. Same for too low but increasing amplitude may lead to distortion. For a quick adjustment the "normalize" option on the "effects" menu will adjust the recording levels to standard listening levels. Also note there are many other options to make adjustments to your previously recorded music or voice.
    Hope all this information has been helpful, and, if so, please mark this thread as solved. Good luck.
    Windows
    Thanks for your answer. I agree with you, mostly, but sometimes it looks like the recording level is too high, and then normalize will not improve the distortion. But do you think that I can trust the automate level?
    So, I just did a test and I do agree that the recording levels do not seem to be accurate because they look substantially higher in a recorded version of the same song. However, even though I can see the difference on the graph, I cannot hear any (noticeable) difference in the volume levels; although the audible difference will not be discernable when you are talking about 0.5db. Also, that normalize will not work unless peak amplitudes are reached so I sort of misguided you in my previous recommendation. Now, there may be others ways of doing it within Audacity but I have reach the limits of my knowledge here so I would suggest you download their help manual and/or play around a bit to see what you can figure out. I really tried to help you but I am at the end of my experience level with Audacity because I just use it on an infrequent basis. Good luck and please consider marking this thread as solved.
    The image shows the original and recorded levels together. Again, it looks like a big difference but it really isn't.
What can you use to record both the internal sounds (hearable in earphones) and the external sounds (my voice) at the same time?
No record of update in Windows Updates & Activation
A couple of hours ago, I restarted my Win 8 tablet. I got a shut down screen showing that an update was in progress. The Windows Update screen shows that my last update was installed at that time, but the Installed Updates list shows the last update was installed on 8/29, 5 days ago. What was...
Can't Record Stereo Mix in Sound & Audio
I can't record stereo mix (things that I hear playing). I have an Asus N76VZ laptop with Realtek audio chip. Installed is the Asus N76 Realtek driver (6.0.1.6710). The thing is; this laptop has a specific sound system called Bang & Olufsen ICE Power. It has an external SonicMaster subwoofer which...
How to record webcam in stealth ? in Drivers & Hardware
I suspect someone is stealing from me. I would like to enable the You cam on both my Win 8 and Win 7 machines and turn the screen off when You cam is minimized and recording, but it will not do it even with the power set to do so at 1 minute as long as You cam is still running and minimized....
As the topic above, I need help :cry: I using Headphone(include microphone) I had the latest Realtek Driver. My Laptop information : Windows 8 64bit 11685
Read more at source: Android malware uses your PC's own mic to record you | Mobile - CNET News
Record Audio? in Sound & Audio
I want to record audio from one of my workout videos to take with me on a trip. In the past, I had done this with audacity. However, when I open audacity now on Win 8, it says there is no sound device. Does anyone know of a way to just record the sound output from my machine? I.e. I would play the...
