Audio Front Panel not working
    Windows 8.1 Pro x64
    I've installed windows 8 yesterday and noted that front panel audio doesn't work (I use a headphone) connecting the headphone to back jack it's work but front not.
    It's a Intel HDA, and using windows's default driver.
    any needed information tell me, and sorry my bad english.
    Please fill in the "My System Specs". We have no idea what hardware you are using.
    Also was this a complete new build? Or was it one that was working with an older OS and now does not work?
    Usually, the Intel HDA is not the PC's audio, but for the HDMI. If you only have the generic Windows installed "HD Audio Codec", that could be one software problem, you need the proper sound driver.
    More info is needed to try and help you.
    Win 8 64-bit
    You need to install the audio drivers for your sound device (Realtek drivers in your case).
    With the generic drivers that are part of Windows, it appears as though that driver is working fine as sound comes out of the normal speakers OK. However, the headphone jack on the front panel won't work properly and even if you manage to get some sound out of it by turning the volume up to max, it won't really be useable as the sound will be way too quiet.
    I have no idea why the Windows generic drivers don't work properly with headphones, but they don't.
    Windows 8.1 Pro x64
    fireberd,
    Filled out info, and yes It's frist time and first windows on this PC.
    Commonly I use Linux and headphones works good! I only use windows for certain things...
    ARC1020,
    I'll try, provide feedback in some time.
    Here is the downloads on the Biostar site for your motherboard
    NM70I-847 :: Motherboard :: BIOSTAR
    Windows 8.1 Pro x64
    Thank you fireberd, but i already find the download link!
    I installed the sound driver and it's now working.
    the 'Jack Sense' of Front panel isn't working, but isn't a driver or windows issue I say this because on Linux it isn't working also, after I will open case and see if i can do something.
    Thread solved, thank you guys that have helped me!
    Since its not working in Linux too, which you should have originally noted, check the front panel audio connection to the motherboard. Normally the "HD Audio" connector is used. Some cases also have the older AC97 but this does not have the jack sensing that the HD Audio does.
    Another possibility is the case cabling or the actual front panel jack board. I built a new system and the front panel Headphone jack was defective. The case manufacturer sent me a replacement front panel assembly to fix the problem.
No sound from front panel in Sound & Audio
Yeah so my front panel is connected to my board but im still not getting any sound Usually in the good'ol versions i would disable front panel detection from the realtek driver utility but i dont have that on this computer
Hi, I'm so so sick to death of this. Microphone won't work at all. The plugin for the headphones works SOMETIMES. Right now it's not. It's a good system so I'm thinking it's the Creative drivers which are up to date. It's an Audigy card. Not sure what other info will be needed. ...
Right, i've been having this problem since I THINK starting to use a HDMI wire. But now, i cannot get any audio from the audio jacks, they are detected, but no sound is produced and I just cannot figure it out. I've disabled the HDMI, installed, un-installed, re-installed audio drivers and pretty...
I have a Gigabyte GA-F2A75m-HD2 (Rev 1.0) board and this is quite an odd one. The front port worked with Ubuntu and other Linux distros but it seems to be the opposite case with Windows 8.1. I installed the latest Gigabyte version of the Realtek HD Audio Manager but it still doesn't work. What...
Hi, I’m having a problem with the front panel audio of my new Antec One case. While the headphone jack plays sound fine the problem is that it doesn’t detect when headphones are plugged in and does not mute the rear speakers. Jack Sensing is not working at all and Realtek HD Audio Manger marks...
Front panel no left sound in Sound & Audio
Hello, I've got an Z77 Pro3 mobo (Asrock) and a Bitfenix Shinobi case. I've installed the HD-audio plug from the case to the motherboards hd-audio place correctly. My problem is that the case's front panel gives sounds only to my headsets right side but not to the left side. The microphone...
