SRS Premium Sound Uninstall
    Does anyone know how to completely uninstall SRS Premium Sound? I cant find it in add/remove programs, and when I click on the icon from the app search, nothing happens. It doesn't even appear in the control panel. But I know it's having an effect because it's exaggerating the lows of my audio - around 100hz.
    Don't have it myself but this article shows the path to the uninstaller:
    SRS Premium Sound by SRS Labs - Should I Remove It?
    Hope this helps.
    If its installed it is supposed to be in the Add/Remove programs list, according to the link that my2cents posted.
    It may be some other sound enhancement that is causing your low freq issue rather than the SRS. You haven't posted any system specs so we can only guess, but some sound systems, such as RealTek have an HD Audio Manager and Sound Effects/Enhancements is one available feature that can affect sound.
    Okay i've removed SRS, but the issue is still there....do you know of any other sound enhancers which could be responsible? I'm using IDT High Definition Audio.
    Check the Control Panel/Hardware and Sounds. If there is some type of IDT panel, it will be located there (that is where my RealTek HD Audio Manager is located).
    It may be something wrong with the speakers and not the PC audio.
    If I'm not mistaken, SRS sound is tied to IDT Audio. You may want to re-install it, bring up the control panel and disable SRS sound from there.
    If you can't find the control panel or see it, go to C:\Program Files\IDT\WDM.
    Look for application IDTNGUI or the control panel IDTNC64.cpl.
    Quote Originally Posted by Mr Sardonicus View Post
    Awesome thanks alot. There was a massive boost in the sub freqs...it's all good now
Tried to start Malwarebytes on my 8.1 laptop and it wouldn't start but it started on my other laptop. I did wonder if it could be that I was trying to scan both laptops at the same time but I haven't been able to open it since. I have looked on Malwarebytes website and couldn't find a solution...
Hi guys of beloved comunity as i say ou and i am dont presuntous i have a new flamant computer and i want the best security now i install comodo internet security and the new relese was pretty ligth, very good perfomance etc. I have a cuestion i have the luck to win a webroot licence for 1.5 years...
Office 365 Home Premium question in Software and Apps
If I get an Office 365 Home Premium Sub and hand out the 4 extra licences to family they can sign in with their own Microsoft accounts and use their own OneDrive etc. My question is - do I have to keep signing in to my account to keep their accounts alive?
Hi Everyone. I wish to upgrade my pc from Windows 7 Home Premium 64 to Windows 8 Professional 64. I have purchased and received the Windows 8 Professional (Upgrade Edition) 32/64 DVDs. I have a few questions tho. Do I need to disable Norton Internet Security (NIS) 2013, before I ...
Gesture2Launch Premium edition in Software and Apps
Hi Guys, Now You can get the Gesture2Launch premium edition by inviting 5 or more friends to download its full version. For details, you can check: http://www.linpus.com/downloads_gesture2launch_invite.php The premium edition of Gesture2Launch supports user customized gestures, so that...
I have not used these disks in a few years, and am wondering if it is a problem with the disks not being used for so long, or if it is in a Win 8 Issue. The disks, as I mentioned have been sitting around unused for years, since it was installed on my previous Desktop which blew up. I have attempted...
