Split audio
    Windows 8 Home
    Split audio
    Hi, just gone back to Windows after using Mac OS for several years and was wondering if the following was possible.
    To have my Voice Chat program (Mumble) and game sounds to come through my headset, mumble is currently working fine. And then my game sounds to also come through my headset. But then other sounds to come through the speakers (e.g. Spotify, Chrome).
    Also my headset is USB.
    Thanks
    Adam
    Not that I know. Perhaps search for some software that will allow you to do that. However, i doubt that you will find any.
    Windows 8 Home
    Unfortunately had a look for some third party apps, but no luck as of yet. Airfoil does something similar but that only has the option of my computer speakers and my Airplay Speakers, no headset.
Split audio
Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers. I am wondering if there is audio management software. Similar to how if I am on Skype I can...
Solved split screen in email in Browsers & Mail
when I click on newsletters in outlook I get a split screen, and once I get it I cannot get rid of it. is there a way to dump the split screen? can I keep it from popping up in the first place and just have what I click on to open a new web site, page, what ever it's called? and I keep...
Split screen in General Support
Can't view a website and the Excel web app via the split screen. Windows 8 keeps replacing one with the other. I do know how to have 2 sites up at the same time. I access the Excell web app via Sky drive. Is that the problem?
Hi, At my organization we have a very large touch screen tv that we are planning on running windows 8 on. What we want to do with it is somehow have a split-screen setup where a fraction of the screen will run advertisements from our sponsors, and the other portion will just be the normal...
Screen split into 8 views in General Support
The screen is split into 8 views immediately from when laptop starts. (2 across and 4 down) Odd thing though is that an external monitor connected only shows the one view. Also the screen will go blank (purple background) every two minutes or so for a few seconds before the screen comes back. The...
