mic problem
    mic problem
    im having a proplem that each time i voice talk with anyone on yahoo or skype or teamspeak
    he can hear me but also can hear things on my pc like my music or any voice come
    anything i can do it to disbable them from hearing what i hear ?
    still no help ?
    My house
    Windows 7 Home Premium x64
    If you are using a External Mic separate from a video camera, it may have very sensitive to noise picking up sounds around you. If you are using a built-in Mic from a camera, most likely it will pickup background noise as well due to it not have noise cancellation technology. Basically there is no way you will be able to disable background noise unless there is no background noise. Hope I answered your question.
    Windows 8 Pro
    Use a headset , it won't stop them hearing external sounds around you , but it will cut down on what they hear as the microphone is more directional.
    its not sound around me ... its the sound on my pc like if im hearing music from my headset they can hear it while we voice chat... even people around me can't hear it
    My house
    Go into Control Panel and open the Sound options, select the Recording tab and then right click the mic you are using and select properties. Next, select the listen tab and un-check "Listen to this device" and then apply the changes and press ok. Now, the person you are talking to shouldn't be able to hear your music . Hope this solves your problem, sorry I didn't mention this earlier, thought it was a different issue.
    thanks
    My house
    your welcome, glad I could be of assistance!
    I have the same exact problem...and the above advice doesn't work for my problem. My box is already unticked when I went to follow the suggested method.
    Very annoying....any advice welcomed.....
    yea it didnt work i tried again sry it wasnt helpfull at all
Page 1 of 2 12 LastLast
mic problem
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
