mic problem
ad99ooo
im having a proplem that each time i voice talk with anyone on yahoo or skype or teamspeak
he can hear me but also can hear things on my pc like my music or any voice come
anything i can do it to disbable them from hearing what i hear ?
If you are using a External Mic separate from a video camera, it may have very sensitive to noise picking up sounds around you. If you are using a built-in Mic from a camera, most likely it will pickup background noise as well due to it not have noise cancellation technology. Basically there is no way you will be able to disable background noise unless there is no background noise. Hope I answered your question.
    Windows 7 Home Premium x64
    Hewlett Packard P7-1017c
    Intel Core i3-2100 @ 3.1Ghz
    Pegatron HP
    Crucial 2x4GB DDR3 1333 MHz
    Sapphire Radeon HD 7850 2GB GDDR5
    Realtek HD Onboard
    HP 2211x
    Hitachi 1TB 7200 RPM
    Corsair CX600 80+ Bronze
    Coolermaster HAF 912
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    30+ Mbps Download; 2Mbps Upload
    Norton 360
    New build with custom parts later in the year
Use a headset , it won't stop them hearing external sounds around you , but it will cut down on what they hear as the microphone is more directional.
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
its not sound around me ... its the sound on my pc like if im hearing music from my headset they can hear it while we voice chat... even people around me can't hear it
Go into Control Panel and open the Sound options, select the Recording tab and then right click the mic you are using and select properties. Next, select the listen tab and un-check "Listen to this device" and then apply the changes and press ok. Now, the person you are talking to shouldn't be able to hear your music :). Hope this solves your problem, sorry I didn't mention this earlier, thought it was a different issue.
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
your welcome, glad I could be of assistance!
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
I have the same exact problem...and the above advice doesn't work for my problem. My box is already unticked when I went to follow the suggested method.
Very annoying....any advice welcomed.....
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
Well, then all I can say is do not have any music playing while you're using VoIP. Sorry that my advice did not fix your issue. Hope it clears up for you soon!
    Pegatron HP
    Realtek HD Onboard
    HP 2211x
    Stock Intel Fan
    HP Keyboard
    HP Mouse
    Norton 360
