Solved IDT Audio HP ENVY dv6 needed. Accidentally uninstalled
The HP site is the place to download the driver. Drivers from other sources or for non-HP PC's may not work. The sound driver you referenced appears to be the correct one.
What happened when you installed the sound driver you referenced? Did it install? or did it abort? or did it give you some error notice?
At first the installation seems to run smoothly until I get a message during the "Configuring IDT Audio Driver and Applications" segment. The message says " The hardware detected is not supported by this IDT software package. The install will be aborted."
What the exact make/model of your HP laptop? Example....HP Envy dv6-7210us
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
There isn't anything on the surface of my laptop.
I've downloaded the program you suggested. I checked under the category of CPU, but the best I can find is this
Name: Intel Core i7 3630QM
Code Name: Ivy Bridge
Package: Socket 988B rPGA
Technology: 22nm
Specification: Intel Core i7-3630QM CPU @ 2.40GHz
For audio it says:
sound car --> Intel Display Audio
That's all it says under audio.
Using the link you posted, I found this under system model:
Hewlett-Packard HP ENVY dv6 Notebook PC 088B110000305910000620100
System serial number is also stated but I thought it would be irrelevant.
This one didn't install and it actually didn't give me an error message either. The install shield wizard closes on its own and there is no further response.
If it helps, it is beats audio. Says it on the top left corner of my computer, just above the screen.
I tried a program called driver identifier and it says my laptop model is:
Model:​
HP ENVY dv6 Notebook PC (103C_5335KV G=N L=CON B=HP S=PAV/088B110000305910000620100- SKU:C2L43UA#ABL)​
I found this on the HP site about how do I find my model number
How Do I Find My Model Number or Product Number? HP ENVY dv6t-7300 CTO Quad Edition Notebook PC | HP® Support
I looked at the listed DV6 -7300 models and didn't see Beats Audio listed in any of them. I did see Beats Audio when looking before but it may have been for a different model. Beats Audio is not the sound driver, its just an "enhancement" to the basic PC audio.
Those sites such as the driver identifier usually want $$ to download and they are not always correct.
Thanks it even stated the driver needed and the version of it. I was able to google it and I was set from there. Thank you very much. I'm new to this forum . I have just given you a thumbs up and I don't know if there is any other way to thank you.
Cool. Glad it worked and thanks for the Rep and feedback.
