IDT Audio HP ENVY dv6 needed. Accidentally uninstalled
  1. #11
    This one didn't install and it actually didn't give me an error message either. The install shield wizard closes on its own and there is no further response.
    If it helps, it is beats audio. Says it on the top left corner of my computer, just above the screen.
  2. #12
    I tried a program called driver identifier and it says my laptop model is:
    Model:
    HP ENVY dv6 Notebook PC (103C_5335KV G=N L=CON B=HP S=PAV/088B110000305910000620100- SKU:C2L43UA#ABL)
  3. #13
    I found this on the HP site about how do I find my model number
    How Do I Find My Model Number or Product Number? HP ENVY dv6t-7300 CTO Quad Edition Notebook PC | HP® Support
    I looked at the listed DV6 -7300 models and didn't see Beats Audio listed in any of them. I did see Beats Audio when looking before but it may have been for a different model. Beats Audio is not the sound driver, its just an "enhancement" to the basic PC audio.
    Those sites such as the driver identifier usually want $$ to download and they are not always correct.
  4. #14
    Thanks it even stated the driver needed and the version of it. I was able to google it and I was set from there. Thank you very much. I'm new to this forum . I have just given you a thumbs up and I don't know if there is any other way to thank you.
  5. #15
    Cool. Glad it worked and thanks for the Rep and feedback.
Page 2 of 2 FirstFirst 12
Solved uninstalled mcafee in System Security
Hi Shawn. For once my question isn't about my own computer :dinesh:. My partner uninstalled mcafee shortly after getting his laptop, but it seems it didn't uninstall cleanly. There are still mcafee folders in Program files and Program Files x86 and there are still some mcafee related entries in...
I'm new to this, so if I'm doing in wrong, please forgive. Installation of 8.1 won't proceed until I uninstall F-Secure 2010-2011 (v10.*). I could not find F-Secure, so I downloaded the Uninstaller, ran it, and restarted my computer. For some reason, the message keeps popping up and I still...
Solved uninstalled programs in Software and Apps
How do i uninstall programs from the command line, anyone know? I know how to do it in windows, and i did that, but they still are there in my start/metro screen. When i click on them:) they open into a command prompt window. If i click uninstall from metro it just takes me around to add/remove...
-------------------------------------------------------------------- Version EVEREST v2.20.405 Homepage Computer Diagnostics & Network Audits Software | Lavalys.com Report Type ...
How can I get it back? Thanks :D:D
Solved Uninstalled Video App in Software and Apps
Can I reinstall the Video App after uninstalling it :cool:?
