Change (reduce) maximum volume?
    US
    Windows 8 Pro 32-bit
    So, the system volume in the system tray goes from 1-100. 1 is comfortable. 3 is loud. 6 is ear-splitting.
    Is there anyway I can redefine the values for the system volume and set the maximum to like... 10?
    Any time I hit the volume buttons on my keyboard to lower the volume, it goes from 1 to 0 and I can't hear anything, so I hit the volume up button and it goes from 0 to 3 and it's way too loud.
    Right now, I have the volume set to about 3 most of the time, with individual apps' volume controls set really low (like a game set to volume "0.5" out of 100).
    This is just ridiculous. There must be a way to redefine the value for the system volume. Some settings file I can edit or something, if not a nice GUI method.
    Adjust your front speaker level.
    US
    Thanks, this is exactly the effect I want!
    ...except...
    I set the level to "1" and when my volume (in system tray) is at "3" it's still a bit loud, but okay, and at 10 it's teeth-grindingly loud. I need to somehow do this same thing, but with MORE POWER!
    Is there anything else I might try to compound the effect?
    Edit: Other than using per-app volume settings (where available)?
    US
    Actually... nevermind...
    The volume buttons seem to change "levels" as well, so if I set the level to 1 and change the volume with my keyboard, I see the "levels" go up as well.
How to Change Maximum Disk Space Used by System Protection and System Images in Windows 8 and 8.1 System protection is a feature that regularly creates and saves information about your computer's system files, programs, drivers, and registry settings as restore points for all drives that have...
Change the volume image flags values in Installation & Setup
Hi I am using Windows 8.1 Update and Windows ADK. Without using the ImageX command, how do I change the volume image flags values displayed with the Dism /Get-ImageInfo /ImageFile:"<WIM_File_Path>\<WIM_Name.wim" /Index:<Image_Index> command? Where are these values ​​stored? Thanks
Hello, I'm new here and I never browsed this forum before... First of all, my english is basic, so if I don't explain very good, I'm very sorry. OK, what I want to do is the same that a lot of users that have their smartphones (Android OS), is change the original DPI o screen resolution (force...
Hello to everbody It is a way to change the position of the volume indicator ? now is on the upper left of the screen and i want to move it or to make it transparecy
can i change the key, from a volume license kms one, to upgrade retail one?
Hello, Recently I have upgraded my notebook from Windows 7 Ultimate to Windows 8 Pro and then to Windows 8.1 Pro with Media Center. I noticed that the Start screen in Windows 8.1 shows on my laptop's 1366x768 display 4 rows of tiles on the Start screen. However, at home, I usually attach an HDMI...
