the culminator
I have been trying, on and off for nearly a year now and pretty intensely in the last week, to get the stereo mix problem sorted and still nothing.
My system comprises; W8/64bit pro with media centre, asus crosshair v formula mobo, amd 6 core processor, 8gb ram, Creative Audigy SE soundcard. I have main spkrs in the green jack, headphones in the black jack, nothing connected to the blue in or the orange out. My Realtek drivers (R271) are up-to-date. There are no recent updates to the card software (currently version 5.12.1.2018 / dated 03/08/2009). It is set to 4.1 and I can only change the Creative Soundblaster settings thru the 'audio control settings' from the 'soundblaster' tab in 'speaker properties'. There is no win8 support from Creative for a full interface. All the bits n bobs from Creative are installed on my pc but only 'audio control settings' and 'Wave Studio7' are functioning.
I have plugged something in to the blue line-in and Audacity recorded it - no probs.
In sound properties - 'show disabled' and 'show disconnected' is checked, everything is disabled except my speakers turned up full (creative drivers) in playback. Everything is disabled in the 'recording' tab of 'sound' except for 'stereo mix'(realtek high definition audio driver) which of course, does not light up when ANYTHING is playing in the background. The level is up full and it makes no difference if the 'listen thru this device' is unchecked or not. but I dont know the difference between 'default playback device' and 'speakers (sb audigy)' concerning the 'playback thru this device;'? either makes no difference
It has been suggested that I will never get this problem solved owing to the way my mobo has been wired to crack down on users directly recording fom the interweb. I also tried plugging my speakers into the line-in jack...to no avail.
I still can't tell wether this is a problem with my mobo, soundcard, W8, Realtek or Creative.
Any suggestions welcome - thanks in advance.
- windows8
- Computer type
- PC/Desktop
- System Manufacturer/Model
- selfbuild
- CPU
- amd
- Motherboard
- asus
- Memory
- 8gb
- Graphics Card(s)
- Browser
- firefox
- Antivirus
- avgfree
