Asus M4A88T-M sound issue .
    Win 8 X64
    hi, i've just installed Win 8 .
    when it finished , i had sound , but only from 1 speaker ( i have 5.1 )
    i was trying to install M4A88T-M audio drivers , but it says that no HD AUDIO found , and then i tried to install AC-97 drivers , but there's no drivers for win 8 .
    is my motherboard that old ? is there any solution ?
    The VIA audio drivers can be downloaded from ASUS HERE
    The AC97 drivers are old and not HD audio drivers.
    Win 8 X64
    Check the BIOS. If may have been disabled.
    Win 8 X64
    it is enabled there ...
    the jacks are the same right ? doesnt matter if it is HD or AC 97 . ?
    The jacks are the same, some auto sensing is not available in AC97. Considering how new the motherboard is, I would avoid using the AC97 (considering it was developed back in the Win 98 era).
    I didn't see any motherboard chipset drivers, but that is the next issue. Many motherboards have chipset drivers and one of the prime things they do is define (identify) all the devices on the motherboard. If a device is not identified, drivers would not find it.
Hi everyone, I have been struggling with this for weeks - whenever I plug my computer into a TV through an HDMI cable, the screen visual transfers perfectly but no sound comes through the TV. Please note that I have scoured the forums and have tried all of the basic suggestions that people...
Asus hdmi tv sound problem in Sound & Audio
I have a Asus N750JV. My problem is that when I want to play a movie on the Smart samsung tv with my HDMI cable the video is perfect but the sound is still playing from my laptop instead of the tv. 48970 Thanks for helping in advance. Greetings
Hey, yesterday I went from windows 7 to windows 8, everytime I close a game or a program with sound, this buzzing noise comes, and it wont stop until I restart my PC. Might be worth mentioning that the drivers are beta drivers, but they have been since 2012, so the shouldnt be a problem. And yes I...
ASUS Laptop Sound Drivers in Sound & Audio
Hey guys, I've been helping my friend troubleshoot over a combination of phone/Teamviewer and cannot for the life of me figure out what next I should do. She's using an ASUS K55N-DS81 laptop, new from Amazon. It's running Windows 8 64-bit with 4GB of RAM. Main problem: her audio doesn't work,...
ASUS Sound Driver? in Drivers & Hardware
Hi all, so my motherboard is an ASUS model M2N-E and I just managed to fix the problem that prevented me from successfully installing Windows 8 earlier today. Now that I'm running Windows 8, I plugged in a brand new set of Harman Kardon Soundsticks III and the sound quality is terrible. Very...
OK, so I had a similar issue with sound in Windows 8 that has been described multiple times in this forum. 1. The sound was crackling and buzzing so I installed Realtek audio drivers, as suggested in this forum, and it started working; albeit temporarily. 2. The sound will now work fine...
Hi folks I'm currently running the Windows 8RTM 64bit on my Asus eee Slate ep121. I have a dual boot of the RTM and Windows 7 Home Basic. I have several game including Plants vs Zombies and Angry Birds Space that run great on Windows 7, but they won't run on the Windows 8RTM. I keep getting...
