USB mic not working
    USB mic not working
    I have a blue snowball that use to be working but when i changed motherboards it now does not work.
    I have tried refreshing my computer but it still does not work. I have tried to reinstall the realtek hd audio but nope.
    I have tried looking in the sound/recording tab but it does not show up.
    I have no idea what is wrong. The computer detects it and shows the driver in device manager, and shows it in devices and printers, but i do not know what is wrong.
    Thanks in advance
    A corruption between the device (hardware) and Windows could cause this.
    Connect the mic, go to the Device Manager and uninstall the mic in the Device Manager. Disconnect the mic and then restart the PC. After Windows starts, connect the mic and Windows should reinstall it. This MAY fix the problem.
    When I try to uninstall the driver it asks me to confirm the uninstall, i confirm it, then it says its trying to uninstall, but it takes forever and never finishes. Any thoughts?
    Install the Intel motherboard chipset drivers and then the RealTek drivers from the MSI downloads for your motherboard.
    The chipset drivers MAY also take care of the USB mic problem.
    I had just updated my drivers from the msi live update 5 program. I will reinstall the drivers anyway but do you know if those come directly from msi or from realtek and intel?
    I can't say. Some vendors have custom drivers and some just pass on the drivers. applicable to their hardware, from the individual hardware vendors.
    Did you go to Control panel/sound and make it default input device ?
USB mic not working
My usb gamepad stopped working suddenly and never work again in this computer I tried the gamepad in other computers and it works good, but not in this computer, I tried to reinstall windows several times, install all kind of drivers, I tried to configure it in different ways and its not working...
Hi! I am repeatedly getting the error "Internet Explorer not working" / Windows checking for solution/Last browsing closed unexpectedly , then Restore Session. I went to google to find a fix for this error .I'm being told to Press Window + W key then type in Troubleshooting in the Search box , then...
Hi, I updated my Synapse software (Razer) and suddenly my BlackWidow mechanical keyboard isn't working fully. The F keys are not working correctly the F10 mutes and F11/12 turn the volume up and down (almost like it's a laptop keyboard). The Windows key has swapped with the ALT key and also the...
This is my first time posting this but im trying to find a solution to this problem, EVERY key except for the c can be capitalized using the shift key, when i press the shift and the c i get ..nothing..but if i use caps lock and c i get C ...i tried using ctrl and c and that works perfectly...
Solved CPU 50% and without working... in Performance & Maintenance
Hi, My PC: Amd Phenom II X4 955 3.21MHz 8GB Mem 4 HDD 700GB Sata, 500GB Sata, 80GB IDE and 60GB Sata.
Solved W E I not working in Performance & Maintenance
Most people with W8 try out the wei just for fun as it doe's not mean a lot. I personally can confess to three on W7 and three on W8. One of the W8 pc's has just been reloaded from 32 bit to 64 bit and it won't complete wei. It says"COULD NOT MEASURE VIDEO PLAYBACK PERFORMANCE". Any one have a...
Working/Non Working software for Windows Developer Preview AKA Windows 8 Please use color code above when posting your list Paint.NET Google Earth Divx Plus Web Player (free) Logitech webcam software - model, Logitech HD Pro Webcam C910
