Disable Microphone monitoring
JohnMA
How can I disable the microphone monitoring?
Now, when I speak, I can hear my voice in the headset with a small delay.
When I go to the Sound -> Microphone Properties, the "Listen to this device" checkbox is already un-checked in the "listen" tab.
Any suggestions? :)
    Windows 8.1 Pro X64
    i5-4670K
    Z87-Pro
    Kingston HyperX blu 2X8GB, KHX16C10B1K2/16X
    GTX 660
    Samsung 840 Pro 256GB
    BeQuiet Straight Power E9 CM 680 W
    Fractal R3
In almost all cases (all that I've seen), you can't disable it. That is the reason many use a headset/mic combination to minimize feedback problems.
Did you install proper audio drivers for that MB or you are using default win drivers? Manufacturers drivers usualy have more options for it. In my case Realtek drivers have an option for microphone monitoring and it works well from it's own control panel.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
