Mic problem
    Mic problem
    Hello
    i have a problem with my mic it was working normally yesterday night and mid night but when i woke up today my friend said that he cant hear me so i checked my mic setting they were pretty normal then i thought that there should be a problem with the mic then i plugged my old mic it didnt solved either i dont think i broke my jak it was normal yesterday i didnt touch it
    Try System Restore, since it worked OK and now does not. System Restore will not delete any user files or e-mails, just a step backward.
    İ dont think İ have a backup i never do it.will updating realtek hd audio work?
    System Restore is not a complete reinstall. You don't need a backup for that. Its a Windows utility for returning the PC to an earlier date.
    See this: System Restore - How to Do in Windows 8
    Ok thanks for your help İ will try this
    solved it with re installing the realtek hd audio
Mic problem
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
